1st Jul 2020, 3:30 pm | #1 |
Racal digital frequency meter SA502
Hallo, I'm looking for any information about this Racal frequency meter SA502. It's about 1960-61. I think so because I found an SA505 advertisement, with 1961 date. Thanks
2nd Jul 2020, 7:03 pm | #2 |
Re: Racal digital frequency meter SA502
That looks to be a single function version of the Racal SA501A, I don't have either but there seems to be a lack of any pictures on the web, so here are some I archived from eBay around 6 years ago.
David |
2nd Jul 2020, 7:18 pm | #3 |
Thank you David. I can't see any input connector, neither power supply connector, on your pictures. Where do you think are them?
2nd Jul 2020, 8:47 pm | #4 |
The input & output connections of the SA501A are on the front panel, I haven't got a picture showing all of the rear panel, that has the large connectors & must also have the power connector/cable.
Sorry I can't help more, your SA502 looks a bit different, the input maybe on the back as I can't see one on the front panel. David |
5th Dec 2020, 11:20 pm | #5 | |
The above picture is from the back of a Racal SA505A. If it does, then I think the matching 4-pole connector is a Bulgin SA2367. David Last edited by factory; 5th Dec 2020 at 11:34 pm. |
