Old 1st Feb 2020, 11:18 am   #21
Sinewave
Sinewave's Avatar
Default Re: Marconi 1041C
I'll have to make a decision about which way to go. On the drawings they show some as potentiometers, some as variable resistors
The front panel of my 1041C has the following values fitted in the following positions, yet the schematic has the values stated in red
  • RV1 - 100K 100K
  • RV7 - 1K 1K
  • RV3 - 1K 33K
  • RV2 - 330R 10K
  • RV6 - 2K 1K
  • RV5 - 2K 3.3K
  • RV4 - 330R 6.8K
As you can see, there are some differences. Do you recall seeing different values fitted?
I have wondered if this is because of any revisions to later units? Or has someone in the past fit different values in?
I'm unaware of a drawing set which serves from this serial number to that serial number with another drawing set for the later serial numbers.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline
Old 1st Feb 2020, 1:09 pm   #22
Skywave
Arrow Re: Marconi 1041C
No: I can't say that I did - or didn't - sorry. That's a level of detail that has vanished from my memory & I have no notes, etc. of the TF1041.
What you might have there is a TF1041 that is halfway between the B and the C model: mine was like that. Ultimately, you might have to resort to the 'suck it and see' approach.
Al.
Skywave is offline
Old 1st Feb 2020, 6:04 pm   #23
Sinewave
Sinewave's Avatar
Al.
Yep, I may have the transitioning version, as the later ones had a different format for the serial number.
What I'll do then, as the circuit is largely the same otherwise is order the fitted values and the drawing values and see what happens.
Sinewave is offline
Old 6th Jul 2020, 11:39 am   #24
Sinewave
Sinewave's Avatar
Just looking to return to this after the 'lab' has been redecorated and new shelving fitted, now everything is in tidy order!
So, does anyone know of some modern equivalent way of hashing up the Marconi T connector? The type TM5031A. It doesn't look impossible to make....
Sinewave is offline
