Old 12th Sep 2021, 1:48 pm   #1
jdavis6809
Default Datron 1071 Lithium Backup Battery
Hello,
I have a Datron 1071 that works ok
Need advice how change the battery without loosing the cal values
it is soldered in not in a socket
I am going to modify to use a 1/2 AA socket
The present battery is dated 1994 and still reads 3.6v
I know I need to piggy back another battery in parallel or have the unit powered but need to un earth the soldering iron
regards
john davis uk
jdavis6809 is offline
Old 12th Sep 2021, 2:23 pm   #2
John_BS
John_BS's Avatar
Default Re: Re datron 1071 Lithium Backup Battery
Yes, you're right. Just keep the instrument powered, avoid touching anything lively, and perhaps unplug your iron for a few seconds.
John
John_BS is offline
Old 12th Sep 2021, 2:29 pm   #3
factory
And avoid dragging the solder wire against anything else, or the case.
factory is offline
Old 12th Sep 2021, 2:38 pm   #4
Radio Wrangler
Radio Wrangler's Avatar
Have an ask around to see if the calibration parameters can be displayed or downloaded by GPIB, then you can have a safe copy if such a facility exists.
Radio Wrangler is offline
Old 12th Sep 2021, 2:53 pm   #5
Craig Sawyers
Craig Sawyers's Avatar
The procedure is attached
Craig
Craig Sawyers is offline
Old 21st Sep 2021, 5:25 pm   #6
jdavis6809
hello,
thanks
yes I missed the cal section in the manual
john davis uk
