Old 2nd Feb 2019, 12:22 pm   #1
TALKINGWITHPYE
Location: Carrickfergus, County Antrim, Northern Ireland, UK.
Default Yaesu FT817 no SSB
Hello has anyone had problems with an ft817 not working on ssb, mine works ok on fm and am but not on ssb. Any thoughts please?
TALKINGWITHPYE is offline
Old 2nd Feb 2019, 12:27 pm   #2
Restoration73
Restoration73's Avatar
Default Re: Yaesu ft817 no ssb
Have you tried going into the main menu and set the SSB mic gain (the default is 50) ?
Restoration73 is online now
Old 2nd Feb 2019, 12:59 pm   #3
MrBungle
MrBungle's Avatar
What frequency as well? Some modes are locked out on some bands.
MrBungle is online now
Old 2nd Feb 2019, 2:32 pm   #4
Barraman
''Not working''........................transmit or receive or both?
Barraman is offline
Old 2nd Feb 2019, 2:58 pm   #5
TALKINGWITHPYE
Thanks for replies, I have been looking further and discovered no receive or transmit and ssb mic is set at 50. I have taken the covers off and can't see anything loose but looking for dry joints would be a nightmare.
Old 2nd Feb 2019, 3:07 pm   #6
SiriusHardware
...And is that on all bands as well?
If you have not already tried it, just try doing a factory reset before looking for hardware causes for the problem - it could save you from disturbing the hardware / dismantling things unnecessarily.
If, after that, it looks like a hardware problem, the service manual (technical supplement) should be a good place to start.
http://www.fracassi.net/iw2ntf/manuali/FT817_serv.pdf
SiriusHardware is online now
Old 2nd Feb 2019, 3:11 pm   #7
TALKINGWITHPYE
Testing on 40metres and 15 metres beside my ft840
Old 2nd Feb 2019, 3:42 pm   #8
TALKINGWITHPYE
Thanks Siriushardware, you hit it, a factory reset did the4 trick.
Old 2nd Feb 2019, 4:10 pm   #9
TALKINGWITHPYE
Thanks mods problem solved this one can be closed.
Copyright ©2002 - 2019, Paul Stenning.
