Old 29th Jan 2019, 11:23 am   #1
M3VUV51
Default Yaesu FT-290 MK1
Hi all I've just dug out my old 290, just noticed it only tunes in an upwards direction, anyone seen this before?
Cheers, M3VUV.
M3VUV51 is offline
Old 29th Jan 2019, 11:49 am   #2
HamishBoxer
HamishBoxer's Avatar
Default Re: Yaesu FT-290 MK1
Possibly key pad switch if it has one sticking?Or I am totally wrong and it is tuned via a knob.
Tuning step switch causes issues.
There is a Yaseu forum that (www.whelan.me.uk/radio/mods290i.htm) might help.
G8JET BVWS Member and V.M.A.R.S
HamishBoxer is online now
Old 29th Jan 2019, 1:03 pm   #3
G6Tanuki
G6Tanuki's Avatar
I'd be checking the outputs of the rotary-encoder first; I've had problems with these on Yaesu gear in the past (my old FT-2400 is on its third one....)
G6Tanuki is offline
Old 29th Jan 2019, 1:19 pm   #4
SiriusHardware
I had a problem on a Kenwood TS50 where buttons not working on the front panel were due to a fault on the CW key socket, because one of the switches in the socket was essentially one more button on the keypad and it was stuck in the closed position and preventing the uP from scanning any of the other buttons while it waited for the 'button' in the CW key socket to be released.
However, only tuning in one direction would normally be a fault with the rotary encoder which is what the tuning control probably is. They are common enough, just getting one with exactly the same size / type of shaft and pin footprint could be a problem. With great care, you may be able to take the original encoder apart and fix it.
Edit: Tanuki beat me to it.
SiriusHardware is online now
Old 30th Jan 2019, 1:01 am   #5
M3VUV51
May have a look at some point. TBH I hate these rigs ,total pigs to work on, total Yaesu under built junk!!
M3VUV51 is offline
Copyright ©2002 - 2019, Paul Stenning.
