Repair and Restoration Services Wanted If you need someone to repair or restore equipment for you please post your request here. |
26th Jun 2024, 8:20 am | #1 |
Do you service Sony WMD6C Walkmans?
If so, please get in touch by PM:
I have a couple of these machines which need mechanical overhaul. It's the usual stuff, belts, tyres, re-lubricating, etc. When I last looked, a while ago, the mechanics were otherwise fine, but I'm aware that some Sony plastic gears can split (an issue on DAT drives), so they might be worse than I imagine. I no longer have the dexterity to do this myself, however I have some transfers to do and would like to get them both working again, as I've no other Dolby C decks. If you're able to do replay alignment at the same time that would be even better! Obviously, I'll pay the going rate. Many thanks, S. |
27th Jun 2024, 3:30 pm | #2 |
Re: Do you service Sony WMD6C Walkmans?
These are nice machines, so my choice would be Peter Dolman:
http://www.dolmanav.co.uk/ Last time I checked, he had a 6-month waiting list and he won't be cheap, but his reputation is 2nd to none. Check the tapeheads site for references. Another person I have used is Michael Merry (Sidcup, Kent). This is the only info Google shows me: https://theartofsound.net/forum/archive/index.php/t-76612.html |
