11th Dec 2019, 7:02 pm | #1 |
Optical fibre between infra-red RX and TX LED’s?
If I’m linking infra red LED’s with optical fibre, what’s the best way to couple the LED’s and cable ? I haven’t ordered any yet as I need some clarity on this. Are there multiple diameters avail? It’s a low bandwidth and low frequency application and only a very short distance .
Any info much appreciated - following thread but I may not respond very fully for a few days . Thank you
Al |
11th Dec 2019, 7:22 pm | #2 |
Re: Optical fibre between infra-red RX and TX LED’s?
I can't help you with your specific question but is this by any chance so a bedridden person can operate a TV box which is below their line of sight?
We had a problem like that when an elderly relative was confined to bed and a bed was set up facing the TV in the lounge, but the receiver box was below line of sight, masked by the end of the bed, and for complicated reasons wasn't easy to move. We solved it then by acquiring a child's toy periscope and fixing it to the rail at the end of the bed. |
11th Dec 2019, 7:30 pm | #3 |
What is the 'receiver' at the other end of the IR LED?
There are various grades of fibre: single-mode, multimode, what's the distance? Yes, there's a range of fibre used: generally identified by "OM" numbers - see https://www.fibercables.com/blogs/fa...3-and-om4-mean For short-range multimode I'd go for OM5: https://community.fs.com/blog/three-...tic-cable.html and aim to use the little "LC" connectors. Always remember that the cost of the fibre is low compared with the labour-cost of installing/terminating/testing it! |
11th Dec 2019, 7:33 pm | #4 |
We have speakers in our bathroom ceiling which are connected to a Radio/CD player in a neighbouring bedroom. I ran a few metres of cheap 1mm diameter polymer (acrylic i.e. PMMA) fibre from a top corner in the bathroom over the dividing wall and down to a position in front of the player so I could lie in the bath and use the remote to control the player. In a subsequent redecoration this link was taken out and not re-instated. But I seem to recall that it worked well enough. I don't think I needed a collecting lens in front of the bathroom end of the fibre.
Cheers, GJ
http://www.ampregen.com |
11th Dec 2019, 8:16 pm | #5 |
Thank you, G6Tanuki, the receiver’ is an IR device that was paired with the LED when I bought it - it looks like an LED with a flat lens / collimator.
GJ - that’s interesting to note ! Thank you , I’ll look that up
Al |
11th Dec 2019, 10:01 pm | #6 |
You can buy off the shelf solutions for this sort of thing which are probably cheaper and easier than trying to build something yourself (yes, I know you are perfectly capable of building things )
11th Dec 2019, 11:18 pm | #7 |
Paul, good tip, thanks. Can you point me to a decent source ,please ?
Al |
12th Dec 2019, 11:18 am | #8 |
Google 'remote control range extender'.
I've never needed one so can't recommend anything specific. |
12th Dec 2019, 12:54 pm | #9 |
Thank you , Paul .
Al |
12th Dec 2019, 4:25 pm | #10 |
Hi Al, a length of perspex rod. say 5mm dia and quite flexible.
Ed |
12th Dec 2019, 4:35 pm | #11 |
TosLink cables, very cheap.
12th Dec 2019, 6:35 pm | #12 |
Ed, thank you , that sounds brilliant !
MerlinM, thanks, looks good. What is the name of the appropriate sockets?
Al |
12th Dec 2019, 7:11 pm | #13 |
In the 70's Working ar Bradford University, we had some fibre optic given for a school open day exhibition. We used hyperdermic needles.. putting the fibre down the needle and inserting a suitably modified led into the metal header... worked a treat. Bearing in mind it was the 70's when Fibre optic and leds were in their infancy.
Should get out more. Regards Wendy G8BZY |
19th Dec 2019, 10:52 pm | #14 |
Looks good ! Only what sort of physical / mechanical connection could I make to and from IR TX diode/ receiver on a circuit board?
Thanks
Al |
