1st Aug 2009, 1:34 pm | #1 |
Dynatron Ether Stereo - connecting an aerial
Hello there,
I've just got my hands on a massive Dynatron hi-fi set, and I was wondering whether you fellows could give me a hand with finding out how I can attach a radio aerial. I've attached two pictures: - an interesting looking knob on the bottom with a fibrous uninsulated wire attached (this may be the aerial attachment I'm looking for) - the sockets on the back of the hi-fi... I'd appreciate any help with what the two white mouldings do. Thanks, Rhodri |
1st Aug 2009, 2:32 pm | #2 |
Re: Dynatron Ether Stereo - connecting an aerial
The two white mouldings are indeed aerial sockets, one for FM the other AM.
It would be quite common to have an FM aerial made from a piece of 300ohm ribbon, split and splayed out horizontally. For AM, often a single wire was used, and it is possible that the wire in your first picture, was a "pseudo frame aerial" that would have been pluged into the AM socket. Someone who knows that partcular model may be able to give more information. |
3rd Aug 2009, 7:46 pm | #3 |
Those sockets are, as Alan says, FM & AM Aerial sockets. Standard(IEC?)Plugs, obtainable from Maplin, etc. fit them. The FM one is designed to match a 300 Ohm balanced feeder(i.e. a 'ribbon' connector) so if a UK standard aerial with a coaxial cable is to be used a 'balun' will be needed. BTW that wire underneath is an earthing link.
3rd Aug 2009, 7:57 pm | #4 |
If you're in a strong signal area, you can probably get away with one of the simple folded dipoles made out of 300ohm feeder type of indoor aerial (or make up your own).
These consist of one length of feeder about 5' long with each end shorted plus another piece any length you like connected between the aerial socket on the tuner and a break at the centre of one side of the 5' piece so that one side of the set feeder connects to one side of the break and the other to t'other. This will not need any balun as it's 300ohm balanced to start with. Commercial ones have nice little bits of plastic to tidy up all the joints and provide convenient mounting points but it'll work just as well without and a couple of drawing pins to attach it to the wall or similar Chris |
4th Aug 2009, 5:33 pm | #5 | |
You can always poke a bit of stiffish wire into one of the holes in an "emergency" though. N. |
8th Aug 2009, 5:16 pm | #6 |
Hi !
I'm late on this one, but..; These connectors were used in Germany designed sets. Of course they disappeared. I had luck using banana jacks into them. Instead of trying to insert the 4mm kind, get a couple of miniature 2mm one. They fit nicely ;-) |
