Old 3rd Dec 2009, 5:56 pm   #1
Mike Phelan
Mike Phelan's Avatar
Default Circuit, please, for Saisho CT142RX
I think it's a really a Matsui 1440A - not on Paul's database.
Thanks in advance.
Mike.
Mike Phelan is offline
Old 4th Dec 2009, 1:37 am   #2
Darren-UK
Default Re: Circuit, please, for Saisho CT142RX
Available from here, in Matsui guise, if you don't mind digging into your pocket.
Darren-UK is offline
Old 4th Dec 2009, 10:06 am   #3
Mike Phelan
Thanks, Darren, if nobody comes up with one here, I'll have to put some money in my pocket to replace the fluff.
Mike.
Old 4th Dec 2009, 10:12 am   #4
Nickthedentist
Nickthedentist's Avatar
Or try the U-View books in your local main library.
Isn't this the one with the avalanche diode across the HT line that tends to go s/c for no apparent reason?
What's the fault? Might be worth a Google?
Nick.
Nickthedentist is online now
Old 4th Dec 2009, 12:57 pm   #5
Mike Phelan
Thanks, Nick; not a place I visit very often so didn't know about U-View.
Fault is lack of width & height (probably low HT) and it's not electrolytics.
If I can get a circuit I'll sort it, so no worries there.
Mike.
Old 4th Dec 2009, 1:24 pm   #6
ben
ben's Avatar
I believe this is an ONWA.
search here there are a couple. download and compare.
post a pic of the pcb if poss.
Regards,
Ben.
ben is offline
Old 4th Dec 2009, 2:27 pm   #7
MALC SCOTT
MALC SCOTT's Avatar
Orion chassis. I must have repaired thousands of these good little sets over the years. These were Currys/Dixons best selling portable for years.
Check the ht rail. i seem to think it is around the 100v.
If that is down then the STR50103 reg ic is suspect.
Diss the ht feed to the loptx and put a 40w light bulb across the ht smoothing cap and measure it.
The psu is self osc and will run ok with a dummy load.
PM me if you get any problems. Cheers, Malc.
Malc Scott
MALC SCOTT is offline
Old 4th Dec 2009, 2:55 pm   #8
Nickthedentist
Originally Posted by Mike Phelan View Post
... didn't know about U-View.
They were/are a series of annual books containing circuit diagrams of the year's TVs and VCRs. They carried on roughly where Molloy & Poole left off.
Nick.
Old 4th Dec 2009, 3:58 pm   #9
Mike Phelan
Thanks, folks.
Ben, I'll take a pic when I've a moment.
Malc, I'll try what you said, but if it needs more than a component from my junkbox, it will land here as "offered" as it does work.
I'll close the thread and start a new one if I need help, but if anyone has a circuit to hand, please PM me.
Mike.
