26th Nov 2009, 9:01 pm | #1 |
Quiz time!! no audio on VT17 Pye
Hi
I remember being told this story from my old foreman in Clydesdale years ago and wonder if any can think what was the caus of the problem. The lady of the house called in to say her rental Pye VT17 had been loosing sound for a week and now had none. The engineer (name can be supplied) went out to the lady who stayed in Govan, Glasgow. Sure enough there was no sound, the PCL83 was replaced and the voltages checked, the output transformer and speaker speech coil were checked as OK, but still no sound, there was no buzz when touching the grid of the triode. At this point the engineer was pulling his hair out, eventually the set was lifted to the workshop and a loan left. It was an easy job for the bench engineer though. What was the fault? Trevor
26th Nov 2009, 9:14 pm | #2 |
Re: Quiz time!! no audio on VT17 Pye
Well, if the volts on the valve are OK and the connections to the speakers are OK, then maybe R130? (Part numbers on Trader Sheet 1214).
Cheers, Steve P.
26th Nov 2009, 9:16 pm | #3 |
Hi Steve
All OK here, think again! Trevor
26th Nov 2009, 9:33 pm | #4 |
a broken wire inside the insulation?
a Mechanical fault at the speaker cone? |
26th Nov 2009, 9:47 pm | #5 |
YT.
On your second line you are getting warm. Trevor PS what's your christian name?
26th Nov 2009, 9:53 pm | #6 |
Speaker plug faulty?
26th Nov 2009, 9:55 pm | #7 |
Speaker speech coil detached from cone?
26th Nov 2009, 10:00 pm | #8 |
Hi
Getting very close, if so why? Trevor
26th Nov 2009, 10:17 pm | #9 |
Speaker cone eaten by mice?
26th Nov 2009, 10:23 pm | #10 |
Deaf member of the house kept the sound up full for long periods?
Cheers, Steve P.
26th Nov 2009, 10:41 pm | #11 |
Well done Simon. The house was really dark with only one 40w bulb so "Jimmy" couldn't really see the cone or the mouse droppings. The back was off though which was a way in for the little rodent. The following day on the bench the "fault" could be seen right away. He got stick for it for years untill he died in 2000. Award yourself a gold star. Cheers Trevor
26th Nov 2009, 10:56 pm | #12 |
Amazing! I'm sure I have read about mice eating cones but I can't remember where. Thanks for keeping us guessing.
Simon. |
