10th Aug 2018, 9:01 am | #1 |
Dansette Hifi Mystery
Can any one shed any light on this mystery?
In one of the photos you will see a crocodile lead connecting the controls bracket of a Dansette Hifi amp to the amp chassis. This cures a hum which is present with the volume at minimum. However, if I replace the crocodile lead with a permanent lead the hum increases slightly. I've tried different leads but the only one which cures the hum is the crocodile lead! Can anyone think of an explanation? |
10th Aug 2018, 9:06 am | #2 |
Re: Dansette Hifi Mystery
With hum pickup the exact path in space that the lead follows can matter. If you find a temporary layout that works then you should try running the permanent wire along the same path (same route, same end point).
Oh, and I did chuckle when I saw the words 'Dansette' and 'hifi' in the same phrase . Cheers, GJ
http://www.ampregen.com |
10th Aug 2018, 9:21 am | #3 |
Could be an earth loop to the Garrard AT6 deck plate?
Edward. |
10th Aug 2018, 9:30 am | #4 |
The green permanent earth wire in the photo is very close to the on/off switch, if you move it away does it help, if not then has GJ states, make the temp fix permanent.
Frank |
10th Aug 2018, 9:36 am | #5 |
10th Aug 2018, 9:37 am | #6 |
Have you added a 3 core cable when it was originally a 2 core mains cable?
It may help if you put all earth connections to each chassis (controls, amp, deck) onto the same point, possibly the amp chassis, along with the mains earth. Mike |
10th Aug 2018, 9:52 am | #7 |
The Dansette Hifi MKII was ultra linear PP according to the schemo I'm looking at...I think the ECL82 version was as well.
Lawrence. Last edited by ms660; 10th Aug 2018 at 9:58 am. Reason: addition |
10th Aug 2018, 9:54 am | #8 |
In this case, isn't "HiFi" actually the model name?
It was one of their classier models, ending up with an AT6 and p-p ECL86s. Edit: Nobody beats Lawrence to the draw,
10th Aug 2018, 10:03 am | #9 |
Yes 'Hifi' is the model name. This one has 2 x ECL82.
10th Aug 2018, 10:13 am | #10 |
Having repaired one I can confirm that it is Ultra Linear.
10th Aug 2018, 12:00 pm | #11 |
Proximity to a mains cable does seem the likely cause. Many years ago I fixed the hum in a friend's record player by re-routing the screened lead from the pick-up to the amp that had been lying in contact with a cable carrying mains.
10th Aug 2018, 2:51 pm | #12 |
One of the really annoying features of 50Hz hum is that it can come from more than one source. If you're unlucky you can start out with one badly routed piece of wire partially cancelling the effects of another one - two wrongs almost making a right, if you like. The set is delivered to you with the customer complaining about the small amount of uncancelled hum. You notice one of the badly routed wires and, since you understand these things, you move it to a place where it picks up much less hum. Lo and behold, the cancellation is ruined and the total amount of hum now gets much worse ! I've banged my head quite hard against this once or twice .
Cheers, GJ
10th Aug 2018, 3:39 pm | #13 |
Both the Dansette "Hi Fi" ECL82 and ECL86 versions were UL. We may laugh as to the oxymoron of Dansette and Hi Fi, but back in the middle 1950s, the Margolins did make a (very rare) wooden console mono record player with a 3 valve amp, 3 speed changer and an 8" speaker and which would have probably sounded quite decent in it's time.
Edward. |
10th Aug 2018, 4:33 pm | #14 |
I agree Edward. If a hum problem changes when an earthy connection is rerouted, it's very unlikely that the hum is being picked up electrostatically, but likely it's induced magnetically due to AC current circulating in an earth loop. Would that be the mains transformer I see next to the susceptible earth connection? If so, it could be the main source of the induced field.
As Edward suggests, if as usual the deck metalwork has its own earth connection and then maybe the amplifier earth also finds its way to the deck via the cartridge wiring, that could be the source of the loop. One earth connection may have to go. Martin
BVWS Member |
10th Aug 2018, 5:16 pm | #15 |
As well as the considerations above make sure that your wiring is as Pic 1 below.
That is the screen cable to the pickup is connected to chassis at the amplifier end only AND a separate cable is connect between the turntable chassis and the amplifier chassis. Do not use the pickup cable to connect the turntable chassis to the amplifier chassis (as in Pic 2) as this will cause hum. Do not connect both ends of the screened (as in Pic 3) as this will also cause hum. |
10th Aug 2018, 5:59 pm | #16 |
Just a safety warning.
Anyone reading my post no 15 above should be aware that connecting the turntable chassis to the amplifier chassis would be very dangerous if, unlike Ian's "Dansette HiFi", your machine employs the live chassis technique. |
11th Aug 2018, 11:38 am | #17 |
I seem to remember that, as wth the Dansette "Bermuda", these have trailing leads to 3 phono sockets at the back of the cabinet for "EXT LXS", "STEREO" and "TAPE". These are notorious for inducing hum and, what's more, they were rarely ever used.
Edward. |
11th Aug 2018, 12:55 pm | #18 |
