Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 12th Nov 2019, 1:26 pm   #1
Nanozeugma
Nanozeugma's Avatar
Default Taylor 65B RF connector.
I have a Taylor 65B generator (unmolested) which retains its peculiar choice of RF output socket. In time, I will almost certainly replace it with a BNC connector.
I was wondering, however, if anyone has - or has come across - an original lead with matching plug, or just the plug for this socket?
It has the appearance of the sort of two pin bridging plug once much used to select the correct primary tapping on a mains transformer to match the supply. The pins are dissimilar sizes (as with the foregoing) but the spacing is narrower - about 1/4" imperial.
I have attached an image of the socket.
Thermionic Emission, cures depression, boredom and piles.
Nanozeugma is offline
Old 12th Nov 2019, 1:38 pm   #2
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Taylor 65B RF connector.
I'm not familiar with that plug.
I have a Taylor 68, which is a very handy unit, but fitted with a flush Belling Lee coax socket which proved to be quite unreliable in use, when you do really want a constant signal level. I eventually replaced that with a BNC, which may look out of place, but was a big improvement functionally.
B
Data beats opinions most times... that's my opinion, though I have no data on that.
Bazz4CQJ is offline
Old 12th Nov 2019, 4:21 pm   #3
llama
llama's Avatar
It looks awfully like an LT battery connector.
Graham
Half my stuff is junk - trouble is, I don't know which half!
llama is offline
Old 12th Nov 2019, 4:36 pm   #4
TowerRadio
I was about to say the same as llama. I have one if you want it, or are you going to swap for something more high-tech? Les.
TowerRadio is offline
Old 12th Nov 2019, 6:11 pm   #5
Reelman
Reelman's Avatar
I don’t have it to hand at the moment but my Taylor came with a 2” long cylindrical metal tube that has the 2 pin connector at one end and a rubber grommet at the other. From the grommet came a length of twin cotton covered rubber wire, like you see on very old table lamps. Having never opened it I presume it is actually a “dummy aerial”.
Peter
Reelman is offline
Old 13th Nov 2019, 9:16 pm   #6
Nanozeugma
Nanozeugma's Avatar
Peter
Hi Peter,
I should be most interested to see that, should you manage to locate it...
Old 13th Nov 2019, 9:20 pm   #7
Nanozeugma
Nanozeugma's Avatar
Originally Posted by TowerRadio View Post
I was about to say the same as llama.I have one if you want it,or are you going to swap for something more high-tech? les.
I'm on the horns of a dilemma, leave it alone or replace it.....
I'm up in Manchester for a couple of weeks... I'll get back to you when I return, if I may?
Old 13th Nov 2019, 10:25 pm   #8
gezza123
gezza123's Avatar
Here is the one I got with mine.
There is a 0.01uf built in for DC blocking when connecting to an (AC Radio) to block DC from the attenuator. Replace it.
Sometimes I use a (200 ohm) for the Aerial Inputs.
Hope this helps.
gezza123
Name:	taylor 65b rf lead 1.jpg
ID:	193678   Click image for larger version
Name:	taylor 65b rf lead 2.jpg
ID:	193679   Click image for larger version
gezza123 is offline
Old 14th Nov 2019, 8:44 pm   #9
TowerRadio
I have to say that my 1.5v battery connector is NOT the same as the one in Gezza's photos, the pins on the one shown are longer and probably of different diameters. Sorry,Les
Old 15th Nov 2019, 9:11 am   #10
Kevin Hoyland
Hello Nanozeugma.
If you look at my post on the Taylor 65B dated 21aug/2010 yu will see the lead end that you are referring to. If you need a better photo please let me know.
Regards
Kevin
Kevin Hoyland is offline
Old 17th Nov 2019, 1:56 pm   #11
Nanozeugma
Nanozeugma's Avatar
Originally Posted by Kevin Hoyland View Post
Hello Nanozeugma.
Regards
Kevin
Thank you for your input.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
