Old 24th Oct 2021, 5:37 pm   #61
Bigears
Default Re: Homebrew Record Player. BSR UA6 deck and RS Components. Stereo Amplifier.
I have connected the screen cable the inner one to the top tag and the one " outer one copper braiding to the bottom tag ,
Powered up I get nothing from the speaker not even a hum, but when I sent in my OP I was making humming noise When I eventually get it working I will renew the mains lead with earth and replace the old TV aerial
ID:	244138   Click image for larger version
Bigears is offline
Old 24th Oct 2021, 8:47 pm   #62
See post #58. You need to reverse the coaxial cable so that the braid is connected to the lower terminal of the volume control.
While you have the cable disconnected carry out a buzz test as described in post #56.
Station X is online now
Old 25th Oct 2021, 11:52 am   #63
Bigears
OK will do Graham
Bigears is offline
Old 25th Oct 2021, 9:31 pm   #64
Bigears
Default Re: MONARCH BSR Black Box
BSR UA6 made for Pye
Bigears is offline
Old 25th Oct 2021, 9:32 pm   #65
Bigears
BSR made for Pye ?
Bigears is offline
Old 25th Oct 2021, 10:32 pm   #66
Bigears
You mean hold the screw driver by the metal part, won't I get a shock ?
Bigears is offline
Old 25th Oct 2021, 10:35 pm   #67
Unlikely. The amplifier operates at a low voltage, which isn't connected to the pickup leads in any case.
Old 26th Oct 2021, 10:11 am   #68
Audio1950
As Edward has said, the standard UA6, which was used for hundreds of different record players, was modified specially for the Pye Black Box. It had a metal arm, as opposed to the usual plastic one, and a raised "dome" at the rear with the "Pye" logo set into it.
Barry
Audio1950 is offline
Old 26th Oct 2021, 11:20 am   #69
Bigears
Graham, I removed the two wires coming from the pick-up arm from the volume switch leaving the brown and blue connected and carried out the Screwdriver test which was negative, no sounds from speaker, also I have replaced the mains cable with a 3 core cable and earthed it to the chassis, and I am going to replace the TV cable as you suggest, but before I solder them I will send a picture of the wiring using test cables from the Red & Black cables from the picking arm going to the Switch. Regards Ken
Bigears is offline
Old 26th Oct 2021, 11:33 am   #70
Please confirm that with power applied there is no sound from the speaker whatsoever ie no hum or hiss.
Old 26th Oct 2021, 11:39 am   #71
Bigears
no sound what so ever
Bigears is offline
Old 26th Oct 2021, 12:33 pm   #72
Bigears
Graham, here are the pictures of the wiring using test cables from the Red & Black cables from the picking arm going to the Switch. Regards Ken
ID:	244278   Click image for larger version
ID:	244279   Click image for larger version
Bigears is offline
Old 26th Oct 2021, 8:32 pm   #73
I think we'd better find out why you're getting no sound from the speaker.
With mains power applied check that the turntable can be made to rotate under power. This will prove that the fuse in the mains plug is OK.
Then with power still applied measure the DC voltage on the wires coming from the smoothing capacitor.
Old 27th Oct 2021, 9:08 am   #74
Bigears
Hi Graham, Turntable rotates ,DC voltage on the wires coming from the smoothing capacitor reads well it flashers between 8.13- 10.57 Ken
Bigears is offline
Old 27th Oct 2021, 9:37 am   #75
I assume the reading is in volts? It should be steady, check for loose connections, shorting wires etc.
Trace the red and black? wires from the power supply area to the amplifier. what voltage do you see on the amplifier end of the leads? Is the polarity correct?
Old 27th Oct 2021, 1:46 pm   #76
Bigears
OK I did the test again 7.90 volts thats with the red lead of the millimetre going to the red lead red lead of the smoothing capacitor and the black to the black
Bigears is offline
Old 27th Oct 2021, 4:06 pm   #77
If the IC is a SL402 or SL403 type then there's some more general info on them here, starting on mag. page 741 if it's any help:
https://worldradiohistory.com/UK/Pra...cs-1969-10.pdf
Old 27th Oct 2021, 4:08 pm   #78
peter_sol
I assume you had the volume control fully clockwise to do the hum test. That voltage is low for that IC but as it looks like a 6.3v transformer is being used its OK.
peter_sol is offline
Old 27th Oct 2021, 4:13 pm   #79
vidjoman
There looks to be 3 pins of the IC that are not soldered to the PCB. Shown in photo of solder side in post 41.
I get the impression some unknown person (probably a bodger) has tried to fault find in the past and gave up. I see no reason for the 'output' transformer as the IC can drive a speaker directly unless an odd impedance speaker has been fitted. The original circuit does not show a choke in the power supply either.
vidjoman is offline
Old 27th Oct 2021, 4:24 pm   #80
Pins 7, 8 & 9 so far as I can make out.
