13th Feb 2013, 9:17 pm | #1 |
Name that Baird
Hi everyone.
I wonder if anyone can recognise this Baird colour set? I've never seen one before. The ridge around the edge and the flutes in the cabinet look to me excitingly like a Philips single-standard G6, but the tuner buttons and the knobs look more like Thorn so it could well be a less-exciting 3000 / 3500. Thanks everyone. From Mike. PS. Is that a pair of false-teeth on the top-right?
G7TRF |
13th Feb 2013, 9:54 pm | #2 |
Re: Name that Baird
I would say it might be a Radio Rentals set fitted with the Thorn 3000 chassis.
We had one of about the same era years ago and the speaker grille was similarly "dinted". The controls were in a different place as I remember but the tuner buttons were in the same place... Robert |
13th Feb 2013, 10:06 pm | #3 |
Re: Name that Baird
Looks as if it's a smaller screen size; is it 19" or is it 16" screen?
13th Feb 2013, 10:14 pm | #4 |
Re: Name that Baird
I'm not 100% certain but it looks like a 19" then it will be an 8742 fitted with the 8500 chassis, it's definitely a Thorn.
13th Feb 2013, 10:16 pm | #5 |
Re: Name that Baird
13th Feb 2013, 10:22 pm | #6 |
Re: Name that Baird
Yes Jaycee, that's the thought I had; and if it's 16" it could be the 8000 chasis with the 'upside down" tube
13th Feb 2013, 10:34 pm | #7 |
Re: Name that Baird
Definitely not an 8000, the 8500 19" came in two cabinet styles but shared the same model number. That one i'm fairly sure was the later style of 8742.
13th Feb 2013, 10:40 pm | #8 |
Re: Name that Baird
Apart from the 2000 and I think also the 9800 all Thorn delta CRT sets had the tubes blue gun down but the 17" 8000 although still blue gun down had the EHT connector at the top.
13th Feb 2013, 11:05 pm | #9 |
Re: Name that Baird
Definitely a Thorn manufactured set made after 1970. The CRT does not look square enough to be an A56-120X. It could be a 22" set fitted with the A55-14W CRT, if that is the case it will be a 3000 series receiver.
DFWB. |
13th Feb 2013, 11:16 pm | #10 |
Re: Name that Baird
I did think it was the oddball 22" A55-14X but the stand also gives a clue, the 3000 and 3500 chassis sets were much heavier so the stand legs were more substantial.
14th Feb 2013, 11:46 am | #11 |
Re: Name that Baird
Interesting. The control layout may be unique to Radio Rentals/Baird. My grandparents had a 8000 series in the same style, but with a lighter cabinet. We had a 3000 series in the late '70s styled identically to the 8000 in question.
Pity we can't see the back of the set in the photo to see if it's a 3000 or 8000/8500 series! Brian |
14th Feb 2013, 3:13 pm | #12 | |
Re: Name that Baird
Symon. Last edited by Philips210; 14th Feb 2013 at 3:16 pm. Reason: error with CRT number |
14th Feb 2013, 6:44 pm | #13 |
Re: Name that Baird
I seem to remember that early versions of the A55-14X were coded with the old Mazda system as CTA2250. Actually, it's likely this CRT has an RCA equivalent and was used in American receivers.
DFWB. |
14th Feb 2013, 8:06 pm | #14 | |
Re: Name that Baird
That stand gives it away if it's original, they were only ever used with the 19" 8500's. I don't recall a stand for 17” models. |
14th Feb 2013, 9:06 pm | #15 |
Re: Name that Baird
Hi jayceebee.
That's a very fair point, the concave looking sides would then straighten a curved tube such as the 19" thus making it look more straight. It certainly looks odd. I wonder if Mikey405 has the answer. Regards Symon. |
16th Feb 2013, 1:03 pm | #16 |
Re: Name that Baird
I would say thats one of the very early 3000 receivers,
it just does not look right for a 8000 or 8500 |
16th Feb 2013, 7:23 pm | #17 |
Re: Name that Baird
May possibly be a 3000 but certainly not an early one as push through CRT's weren't available until later in production.
I hope Mikey can put us out our misery. |
16th Feb 2013, 8:13 pm | #18 |
Re: Name that Baird
That tube looks far too square to be the Mazda version for the 3000. From memory the corners were more rounded. The tuner buttons scream 3000 but I reckon it's a con and it's fitted with the HMV 1807 chassis just to catch us all out! John.
16th Feb 2013, 8:26 pm | #19 |
Re: Name that Baird
If you look at the photo in post #1 you will see the cabinet has pincushion distortion, obviously an effect of the camera's lens which I suspect is making the tube look squarer than it is.
Cue someone with Photoshop to add some raster correction. Last edited by jayceebee; 16th Feb 2013 at 8:33 pm. Reason: Typo |
16th Feb 2013, 10:33 pm | #20 |
Re: Name that Baird
