11th Dec 2019, 8:21 am | #1 |
Auroral propagation monitoring.
Not quite vintage, although the radio to be used is, almost... and I know we are at sunspot minimum, but.
Ive always been fascinated with the aurora borealis, only seen it once visually but want to set up some sort of monitoring capability to alert me of its presence. Once Ive been through the radio repair pile, Ill have a few spare 2M radios. Ive also a spare 5 ele yagi. thoughts are to set the yagi up on a fixed northern heading, and set a radio up to scan the scandinavian 2m beacons, for signs of auroral reflection. any thoughts on whether this would be a go-er ? Ive also re- found an article in 1982 sky and telescope that describes the construction of a visual monitor, using an RCA 931 photomultiplier tube, and an oxygen passband optical filter used for visual astronomy, but that's another future project. |
11th Dec 2019, 9:10 am | #2 |
Re: auroral propagation monitoring
Sounds good,do we still have the Angus beacon I wonder as I used to monitor that?
11th Dec 2019, 9:32 am | #3 |
LA7VHF 144.451MHz near Tromso could be good for this?
There are many others - see the attached xls Last edited by Jon_G4MDC; 11th Dec 2019 at 9:41 am. |
11th Dec 2019, 9:49 am | #4 |
This is a good application for an old laptop and a SDR: you get the SDR to 'look' at the beacon-band and show the signals on a waterfall-display so you see the entire band-sector in a historic sense (on many waterfall-displays you can scroll-back for quite some time).
11th Dec 2019, 10:24 am | #5 |
Thank you Jon.
11th Dec 2019, 10:59 am | #6 |
Re: Auroral propagation monitoring.
thanks. GB3ANG does appear to still be active, and its also on 1296, which could be useful. close to finishing the 23cm yagi off
https://www.ukrepeater.net/my_beacon.php?id=2053 |
11th Dec 2019, 11:11 am | #7 |
The all important cup of tea is present there!!
I agree that an SDR is a good tool for beacon monitoring. Even the cheap DTV dongle type is fine if the local environment doesn't overload it. Mine is OK but shows some distress if you stray too close to the 153 MHz paging band. Remembering the unique sound of auroral signals I wonder how they would look in an SDR waterfall - a bit fuzzy I suppose. Here is a useful page for Swedish Repeaters and Beacons. https://www.ssa.se/repeatrar-fyrar/ SK2VHF on 144.457MHz from Vindeln JP94TF seems the most Northerly on 2m. Last edited by Jon_G4MDC; 11th Dec 2019 at 11:29 am. |
11th Dec 2019, 11:50 am | #8 |
Sports direct mug complete with weld spatter. Im still toying with a £13 sdr thing to play with
11th Dec 2019, 12:07 pm | #9 |
I doubt you would regret it. I bought 5 at about £6 each a few years ago.
I have given some away and still have 2 or 3 around doing general monitoring. There's a PC in the shack down the end of the garden and I connect to it over Wifi using remote desktop. That brings back the waterfall display quite well but it does a poor job of audio. The bit rate keeps changing introducing nasty tonal effects. RemAud is doing a better job at transporting audio. |
13th Dec 2019, 10:19 pm | #10 |
Hello Steve
unfortunately radio and visual auroras occur at different times relative to each other. This is covered in some depth here https://books.google.co.uk/books?id=...page&q&f=false Not a 'quick read' though.
Regards Pete |
14th Dec 2019, 10:51 pm | #11 |
"Can you find the frequency to locate the capsule or can't you?"
"Well, sir, in zones of visible aurora, you get transmissions in the sporadic E layer." Ice Station Zebra (1968)
-- Graham. G3ZVT |
15th Dec 2019, 12:59 am | #12 |
