28th Jan 2014, 5:17 pm | #1 |
Ferguson 3220 copying to computer
Hi - My first post!
We've got an old Ferguson 3220 reel to reel from the mid 60s and have tapes we want to copy onto PC (I have Dell Dimension 3000 with a blue line input socket). The Ferguson has two outputs - L.S. and RAD. From looking at other threads it would appear that the RAD output is the one to us - the question is what cable do I need to connect the Ferguson to the PC? Grateful for any assistance. Thanks |
28th Jan 2014, 6:03 pm | #2 |
Re: Ferguson 3220 copying to computer
Welcome!
Can you tell us a little about your technical expertise, please? That'll help us guide you through the various steps. I'd double check that Rad is an output rather than a line level input. Regards Graham
Half my stuff is junk - trouble is, I don't know which half! |
28th Jan 2014, 6:48 pm | #3 |
'Rad' is a line input to allow recording from a radio reciever, not an output. Cheers, Pete.
28th Jan 2014, 7:01 pm | #4 |
There is a RAD on the inputs and one on the outputs.
Just to add - I've no experience of mending machines; however this is playing fine. I'm familiar with Audacity so I've no problems at the PC end. I just need to makes sure I'm using the right cable connector at the tape end, and also that it's the right kind of cable. The similar thread that I read was https://www.vintage-radio.net/forum/...t=80903http:// which seemed to imply that if you had a LS and a RAD output, you used the latter. Thanks |
28th Jan 2014, 8:35 pm | #5 |
You need a cable with a 3.5mm stereo jack on one end and a pair of phono plugs on the other. The recorder will only provide a mono signal so you will record this on one channel and noise or nothing on the other. Once this is done it's easy enough in Audacity to convert the mono track to stereo for burning to a CD. Poundland normally sell suitable cables.
This is a very basic domestic tape recorder, and if these recordings are important to you, it may be better to pay someone to digitize them for you. The cost may be quite moderate if you only need to transfer a couple of tapes. A forum member may be prepared to do this for you. |
29th Jan 2014, 10:13 am | #6 |
We should really have a FAQ page with an answer to this type of question, with descriptions on how to wire the cables if the recorder has DIN cables, and which connection to use.
29th Jan 2014, 10:44 am | #7 |
It's been years since I've owned one, but didn't these use the older 'long reach' phonos?
Great idea on the sticky, BTW - I don't mind volunteering to contribute.
Regards, Ben. |
29th Jan 2014, 2:59 pm | #8 |
I took the bull by the horns and produced a 'first steps guide' as I had a bit of free time - hope it is useful!
Regards, Ben. |
29th Jan 2014, 8:14 pm | #9 |
Thanks for all your replies. I've got a cable with a 3.5 jack on one end and 2 male audio on the other; so I'll go to my local pound shop tomorrow and get a female to 3.5 cable to connect to the PC and then cross my fingers. (I did copy cassette tapes onto my PC years ago but not sure which cables I used then - different PC).
31st Jan 2014, 12:27 am | #10 |
I went and bought a "3.5mm jack to 2 socket cable" but the two outputs from my other cable only go in these sockets very loosely. Have I gone wrong somewhere?
31st Jan 2014, 9:29 am | #11 |
Let's have a picture of the connectors that fit each other very loosely then we can advise further.
Thanksl. |
31st Jan 2014, 12:42 pm | #12 |
Two photos attached (I hope) one of the two cables, one of the back of the recorder. The grey cable is the one I've always had and which I think I used to copy from my tape deck to the PC.
As well as the cables not connecting very well, neither 3.5mm jack seems to go into the RAD hole very well. Is it possible to get a 3.5 to 3.5 cable to just link the recorder straight to the line in on the PC? |
31st Jan 2014, 1:24 pm | #13 |
Assuming the RAD sockets are of the Phono or RCA type, there's no way you'll get a 3.5mm jack plug to fit them.
The grey cable should work on its own, but as previously stated you may need Phono plugs with long centre pins.
31st Jan 2014, 3:53 pm | #14 |
Thanks - should this sort of thing do the trick, and then I could connect my grey cable to the PC?
http://www.ebay.co.uk/itm/RCA-PHONO-...item53ec65f1b5 |
31st Jan 2014, 4:39 pm | #15 |
I'm a bit confused!
Presumably, you're trying to plug the red or white phono plugs into the tape machine, and the grey 3.5mm jack plug into the PC? In which case, how does the black male-to-female lead fit in? Do the red and white plugs fit snugly into the tape machine's sockets, as they should? Nick. |
31st Jan 2014, 4:44 pm | #16 | |
I wondered that too Nick.
As far as I can see the grey cable will be perfectly OK on its own, only one Phono pug being used. That Phono plug may need replacing with one having a long centre pin. Phono plug goes into the output socket on the tape recorder and 3.5mm plug goes into the PC input. The OP will also need to take into account Paul Sherwin's comments in post #5. Quote:
31st Jan 2014, 4:51 pm | #17 |
Actually I was trying to get the 3.5mm plug into the tape recorder, then connect the 2 phono males to a 2 female phono with a 3.4mm on the other end of that to go into the PC line in socket!
31st Jan 2014, 7:05 pm | #18 |
Ah, that won't work!
The tape recorder accepts phono plugs, but as Ben points out in post 7, you may possibly need the old-style, extra long version. Usually however, the shorter kind will work if pushed in firmly. N, |
