8th Feb 2010, 7:07 pm | #1 |
Removing adhesive from speaker cloth
I have removed the speaker cloth on a Murphy A 104 to turn it over to use the unfaded side. I have literally "picked off" most of the old adhesive but various unsightly bits remain.
Is there a solvent or some other method of removing the remaining bits? They are all small - about a sixteenth to an eighth of an inch long.
Now that's the kind of Long Wave I like ! (Severn Bore near Gloucester) |
8th Feb 2010, 7:33 pm | #2 |
Re: Removing adhesive from speaker cloth
Depends what sort of glue (and speaker cloth) it is. I had v good results on a Murphy a121 by washing the cloth in warm water with a little washing up liquid.I then dried it between 2 old towels weighted down with wooden boards and a couple of weights. The fabric looks like some kind of loosely woven cotton and the glue was water soluble, probably animal glue of some sort.if yours is a man-made cloth with a modern type synthetic glue like EvoStick you'll need a solvent to shift the glue.I've used meths on evostick but try it on corner first to check that it doesn't affect the fabric. Good luck.
Terry
Terry the Morganist |
8th Feb 2010, 7:36 pm | #3 |
Thanks, Terry. I would say the fabric is woven cloth. I will try both your methods on a bit which will be hidden from view once it's back in place.
John.
8th Feb 2010, 7:47 pm | #4 |
Yep, instant success with warm water and Fairy Liquid.
Many thanks, Terry. Cheers, John.
9th Feb 2010, 6:03 pm | #5 |
It may shrink. Be ready to stretch it.
Jim Mac |
9th Feb 2010, 11:22 pm | #6 |
Thanks, JimMac. I was careful to only wet the bits where the glue was and I used an old toothbrush to gently scrub those bits. It has dried out OK and there are no signs of shrinkage.
