Old 6th Nov 2015, 11:42 pm   #21
wd40addict
wd40addict's Avatar
Default Re: Ceramic and Crystal cartridge specs.
Excellent work!
Does anyone know what the difference between the various BSR stylus types such as ST12/14/15/19 actually is?
Also the list is a bit light on Ronnette, see further attached data from a Finnish website.
The TX88 showed what could be achieved in frequency response and fidelity from a crystal cartridge. Even 'Gramophone' magazine were impressed!
Paul
wd40addict is offline   Reply With Quote
Old 7th Nov 2015, 12:06 am   #22
ben
ben's Avatar
Originally Posted by wd40addict View Post
Does anyone know what the difference between the various BSR stylus types such as ST12/14/15/19 actually is? Paul
I was going to add an explanatory bit on the different BSR styli but forgot! There is a chart in the document indicating the characteristics of sonotone 2509/3509 styli types, so a similar BSR chart would probably be a good addition. Will get to it.
To answer your question: ST12 is LP/78, both sapphire. ST14 LP/78, but LP tip is diamond. ST15 dual diamond LP tips. ST19 is single diamond tip (not flipover).
Thank you for the Ronette info. Will add it to the next update.
Ben.
Old 7th Nov 2015, 7:59 pm   #23
david freeman
Excellent information Ben.
The TC8S had a recommended tracking weight of 5 to 9 gms, usually set to 7 gms in the BSR changers.
david freeman is offline   Reply With Quote
Old 7th Nov 2015, 9:41 pm   #24
ReelToReel
Thanks for this Ben, I have saved a copy
Cheers Mark
ReelToReel is offline   Reply With Quote
Old 8th Nov 2015, 1:36 am   #25
RojDW48
RojDW48's Avatar
Really useful! Many thanks - Roger
RojDW48 is offline   Reply With Quote
Old 29th Apr 2016, 10:21 am   #26
Nickthedentist
Nickthedentist's Avatar
Following on from post 24, I have an instruction leaflet for the BSR Ful-Fi TC.8SM
Styli: TC8RS (yellow, microgroove), TC8G (green, 78s)
Tracking Weight: 5 to 9g
No output voltage stated.
HTH,
Nick.
Nickthedentist is online now   Reply With Quote
Old 7th May 2016, 7:46 pm   #27
ben
ben's Avatar
Just a quick update to say I'm working on a second edition of that chart incorporating data contributions made since the first was uploaded.
I'm still after the following data:
BSR
-SX5M, SX5H: output, tracking force.
-SC7M: output, tracking force.
SONOTONE
-8T: tracking force
-9TA (original): tracking force.
RONETTE:
-TO284 : Stylus reference.
I also have a new section for PHILIPS heads and am after data for the following modules:
GP214, GP215.
Ben.
Old 12th May 2016, 8:06 pm   #28
lazythread
Hi Ben,
I think the Ronette 284 came in 2 versions, the screw held Pfanstiehl ref. 700 (Collaro Studio type) and later ones had the clip-in version, Pfansteihl ref. 702 (Ronette 105 type). I have a later one but it's packed somewhere safe so I can't check for you, sorry.
Looking at a Vernitron leaflet that came with a 9TAHC I bought recently it says the following:
2T: 9 grams
8TA4: 5 grams
9TA: 2-4 grams. All to be loaded with 1-2 megohm
HTH
Richard
It's great when it goes around to make a sound.
lazythread is offline   Reply With Quote
Old 29th Jun 2016, 6:16 pm   #29
GeoffK
Hope this is useful.
GeoffK is offline   Reply With Quote
Old 30th Jun 2016, 1:18 am   #30
ben
ben's Avatar
Thanks! Will add to the document in due course.
Ben.
Old 11th Feb 2018, 1:59 pm   #31
lazythread
Default Re: ERC compat X2 cartridge.
Copied from this thread: https://www.vintage-radio.net/forum/...d.php?t=143847
I have a Compat C cartridge, the box and information sheet say "Stereo Compatible Mono Cartridges" and contain the following data:
"Compat X - Medium Output Crystal Cartridge, output 225mv, VTF 3-5g, load 1MΩ 100pF
Compat X2 - High Output Crystal Cartridge, output 525mv, VTF 6-9g, load 1MΩ 100pF
Compat C - Medium Output Ceramic Cartridge, output 170mv, VTF 5-6g, load 1MΩ 100pF
Electronic Reproducers (Components) Ltd. Hedley Road, St. Albans, Herts."
These cartridges were also boxed and sold by Goldring.
Richard
Old 28th Jun 2018, 2:09 pm   #32
Restoration73
Restoration73's Avatar
Addendum to #32 ; the production of ERC cartridges was taken over by Musonic who
seem to make them in batches dependant on demand. All the specs you may find useful
are on the website. The 2SB is an excellent stereo ceramic cartridge with high compliance
and channel separation (I have no commercial link);
https://www.musonic.co.uk/index.php?...ducts_id=18711
Restoration73 is offline   Reply With Quote
Old 20th Aug 2018, 9:31 am   #33
ssnjimb
Hello
Is there a nude eliptical stylus for a bsr sc12m/h
James
ssnjimb is offline   Reply With Quote
Old 20th Aug 2018, 10:11 am   #34
Restoration73
Hi James
As far as I can remember, the only ceramic cartridge that had an elliptical stylus option was the Decca Deram.
Tony
Old 23rd Sep 2018, 6:32 pm   #35
Chris55000
Hi!
Whilst I have plentiful knowledge of circuits, I've just realised one small piece of knowledge is missing from my knowledge store!
The High Output Crystal and ceramic cartridges are mostly quoted as 600-1200 mV per cm/s, can someone enlighten me:-
Is this linear or circumferential velocity, and what would the recorded velocity of a typical 45 rpm 1960s single, equated in cm/s be?
This would enable me to estimate the p-p voltage at the cartridge O/P terminals, for use with valved or transistorised amplifiers!
When I last repaired record-players I'd no oscilloscopes to hand in those days!
Chris Williams
Old 23rd Sep 2018, 7:56 pm   #36
John10b
Chris i asked this question a while ago, if you look under Components and Circuits, Cartridge Specification, you should find your answer.
I found it very interesting.
John10b is offline   Reply With Quote
Old 23rd Sep 2018, 7:58 pm   #37
John10b
I should have said Page 7
Old 23rd Sep 2018, 8:00 pm   #38
Chris55000
Hi!
Thanks John!
I knew I can't have been the only one puzzled by this!
Chris Williams
Old 14th Oct 2018, 12:22 pm   #39
Restoration73
Addendum to #35 ; I had forgotten that Goldring produced an elliptical stylus for the
CS90 cartridge, which was denoted as CS91E.
Old 1st Jul 2019, 5:41 pm   #40
Alf Fisher
Hi, does anybody have the spec particularly the output of a Garrard GCS10 cartridge please.
Cheers, Alf
Alf Fisher is offline   Reply With Quote
