Old 18th Jul 2019, 6:50 pm   #1
EF80TVVALVE
EF80TVVALVE's Avatar
Default 'Blown' speaker repair help
Hi all,
I've recently had a problem with the speaker in my car and thought I would get it out and try to repair it. It is a mid 1980s VW speaker and surprisingly still the original date stamped from 1985.
It has recently started distorting at any volume and I was expecting to see a damaged cone, but it actually looks fine. When I tried it I pressed onto the cone and it started working as it should whilst I applied pressure but soon distorted again once my fingers were off. There's no coil rubbing or anything bad, just wondering if there is anything I can do to fix it before I buy a replacement.
If anything I would say that the edges of the cone feel a bit thinner and they obviously have some kind of finish applied, maybe to help tighten up the edges of the cone?
I've attached a photo just to show the condition.
ID:	186887   Click image for larger version
EF80TVVALVE is offline
Old 19th Jul 2019, 6:08 am   #2
tony brady
Default Re: 'Blown' speaker repair help
I expect one of the braided wires has broken at one end.
with care they can be soldered to repair the break though access could be tricky
tony brady is offline
Old 19th Jul 2019, 9:51 am   #3
boxdoctor
It might be worth checking that the speech coil is not becoming detached from the cone. This can be done by careful inspection in a good light, and gently physically moving the cone at the same time.
If detachment is observed/suspected, judicious application of a minimal amount of an acrylic adhesive may save you the expense of a new speaker. Tony
boxdoctor is offline
