18th Jul 2019, 1:11 pm | #61 |
Re: Aerial for old valve sets.
That is OK as a starting point for someone who knows nothing about antennas, but I spotted a few errors on the first page.
18th Jul 2019, 1:16 pm | #62 | |
Which are the errors on the first page? Lawrence. |
18th Jul 2019, 3:01 pm | #63 |
G8HQP Dave, I dont understand your statement "Being short is not a problem." Maybe I am mis-reading that.
I know from practice and experience, at the MW & LW frequencies we are talking about here, that the longer an aerial (within reason) the stronger the signal pickup is. A simple test with a 2 foot wire in the aerial socket of a set, compared to a 10 foot wire will show a distinct difference, whether it is vertical or horizontal. The longer always gives a stronger signal, (both wanted signal and unwanted interference) if you use a 60 foot wire it is stronger still. But moving the wire away from the interference loops around the house, as I have, has greatly reduced the unwanted interference. In the case of my inverted L aerial with a long and high horizontal part, I would eat my hat if the reception strength did not drop significantly if I replaced the horizontal wire with a rope. Mike Mike Last edited by crackle; 18th Jul 2019 at 3:14 pm. |
18th Jul 2019, 4:17 pm | #64 |
I am finding this discussion theoretically and practically fascinating since no matter what aerial I try, RF interference increases in direct proportion to increasing signal strength in my abode.
So today I conducted an experiment with a Marconi T29A which has an internal foil aerial and is connected by three core cable to mains earth. Here is the test rig: 1. Well away from the house the set was powered by a generator and obviously no mains earth. RF interference was negligible on and off station. 2. Then the set was connected to the mains with the same result. 3. Then the aerial socket was connected to a few metres of wire and signal strength went up but no increase in RF interference. 4. Then I couldn't resist connecting the aerial wire to the metal framed greenhouse and signal strength further increased but no increase in RF interference. From this I conclude that my local in house interference is not specifically mains borne, either from the two mains conductors or earth conductor, but does not preclude the ring main radiating signals picked up from other sources. So this type of set will always pick up in house interference via its internal aerial although a well designed external aerial would perhaps help to swamp the unwanted house noise. Maybe I should just stick to FM sets! Last edited by DoubleWound; 18th Jul 2019 at 4:44 pm. |
18th Jul 2019, 7:09 pm | #65 |
Lighting circuits are often the worst, with separate runs of live to the switch. Also above the foil backed plasterboard.
18th Jul 2019, 9:27 pm | #66 |
Spent a little more time with the 40 inch loop today. Re hashed the feeder and capacitor connections with very good results. Took the aerial and the Trio R600 outside. Tuned around MW for a weak station, rotated the aerial for best reception then tuned the capacitor with surprising results The S meter went up from S3 to + 20 dB. So the loop is working!
Capacitor tuning only varied a little on MW and as previously reported the aerial is very directional. The results on LW not as clean cut. Still a strong clear signal but capacitor tuning not as sharp. I read somewhere that for LW it is advisable to remove one of the aerial loops 6 instead of 7, but didn’t have time to try this. I have looked on the internet for a smaller loop that would be more convenient indoors but the only thing I kind find are several American articles on ferrite or “loopstick” aerials. Has anyone come across a smaller design that still works?
Never buy a mermaid a pair of socks! |
18th Jul 2019, 11:24 pm | #67 | |
With an L aerial, the horizontal part does not in and of itself pickup much vertically polarized signal, but it increases the effectiveness of the vertical, resulting in more signal. That is nicely explained by Sturley (pp.73-75), with the comment that a horizontal-to-vertical ratio of 1.0 increases the effective height to 0.6h, the nominal being 0.5h. Cheers, |
18th Jul 2019, 11:59 pm | #68 |
Sturley also provided a useful commentary on anti-interference aerials, attached:
Sturley Interference Reducing Aerial Systems.pdf The commercial versions of this type from the major aerial manufacturers appeared to be named as follows: Aerialite: Mastatic and Antistatic Antiference: Exstat Belling & Lee: Eliminoise (with the vertical rod aerials known as Skyrod) All offered their systems for use with both vertical rod and L aerials, and all used twin-screened feeders. The BBC had its own version using a Skyrod and coaxial feeder: BICC did differently, offering a 60 ft dipole with a coaxial feeder and matching transformers at the aerial and receiver ends. Cheers, |
19th Jul 2019, 11:39 am | #69 |
In the mid 1970's we moved from the coastal village of Coverack to Helston. It was a MOD housing estate and all the houses had large gardens.
I installed my HMV 1124 valved radio in the bedroom connected to about 60' long wire aerial across the garden to a fairly short makeshift wooden post at the bottom of the garden with the earth connected to the mains earth. Reception was ok but the lower frequencies including the Long wave, Medium Wave and the lower frequency short wave bands were effected by electrical interference from the surrounding houses, nearby shops and some nearby small local industries. I remember I was getting a continuous warbling sound in the background of BBC R2 on 1500m and during the evenings interference from television sets was severe with that loud whistle on Long Wave and a continuous hash like noise across much of the Medium and Short Wave Bands. I was given a slightly taller more solid wooden post and lifting the height of the long wave by about a meter aerial did improve reception with quite a noticeable drop in noise and interference levels and that warbling noise in the background of BBC R2 on 1500m cleared. But the dramatic improvement in reception, especially the reduction in electrical interference and noise came courtesy of the GPO. They installed a nice earth post in the garden just below my bedroom window. Using this earth instead of the mains earth made a huge difference and as well reducing the local electrical noise and interference but improved the signal pick up especially on the lower frequency bands. Reception of all the BBC stations from Redruth, Start Point and Droitwich was loud and clear with no background noises heard. During the daytime I was now able to listen to the more distant IBA local stations from Plymouth and Swansea as well as pick up RTE from Cork and Manx Radio. Looking back I think this was an important lesson demonstrating the importance of a good radio earth when using a long wire aerial. I am not sure how this would fare today but I suspect it could still make a big difference. Sadly where I live now I am unable to install a decent radio earth.
Simon BVWS member Last edited by Hybrid tellies; 19th Jul 2019 at 11:49 am. |
19th Jul 2019, 12:45 pm | #70 | ||||||
It seems to have been written by someone with lots of experience in using antennas but a rather weak grasp of the underlying principles. Hence myth and truth are mixed together. Quote:
Roughly speaking, the vertical height of the antenna is what picks up the signal (at least for local MW/LW stations) and the total length (including any horizontal top) sets the impedance so can help matching to the receiver. Note that when I say 'vertical height' I do not mean how high up the antenna is, but the vertical distance from the lowest point to the highest point. However, if the receiver is up in the air itself (e.g. in a bedroom) then the height of the receiver above ground can be added if it has a good earth connection. |
19th Jul 2019, 1:18 pm | #71 | |
Today I isolated all circuits in the house except the cooker spur and I still got interference. Just don't know where it's coming from but it's not there in the back garden! Playing around with my chimney mounted FM dipole today I found that the Marconi T29A reception and interference was improved to almost perfection over the range 200m-250m by connecting just the downlead screen to the set's earth socket (which is already mains earthed). It's all weird. |
19th Jul 2019, 1:50 pm | #72 | ||||
http://www.esr.se/phocadownload/ante...0TM_11-666.pdf Lawrence. |
19th Jul 2019, 5:24 pm | #73 |
These sort of pages play a useful role, provided that people realise that they have somewhat oversimplified things and are therefore willing to unlearn some of the misleading details as they progress in understanding. Otherwise they may become yet another propagator of antenna and feeder myths on websites.
19th Jul 2019, 6:34 pm | #74 |
Conclusion, a ferrite rod or a loop (15cm to 40cm diameter) is simpler and less interference on LW/MW.
The ferrite is poor on HF and rubbish on VHF. A 1 to 3 turn loop will work on SW (depending on band), but at higher HF and VHF a whip is fine. |
19th Jul 2019, 6:37 pm | #75 | |
I've had it on file on my PC for years and found it helpful and I know other folks have found it helpful too. Here's a book link to the said, see pages numbered iii and iv near the beginning for an overview of the series: https://books.google.co.uk/books?id=...0radio&f=false Lawrence. |
20th Jul 2019, 3:20 am | #76 | |
Another useful book is “Receiving Aerial Systems” by I.A. Davidson. I think it was originally published by Heywood, and then republished in 1957 by Philosophical Library. It includes a worked example calculating the signal voltage available at the receiver from a 15 ft vertical looking into a range of impedances. The attached article from WW 1949 March covered an effort by the Radio Component Manufacturers’ Federation to classify AM aerials according to their suitability for various field strength ranges. I suspect that these days, only Class A would have some possibility of being out of the worst of the interference field. Cheers, |
20th Jul 2019, 12:53 pm | #77 |
A very interesting thread & I thank everyone for their input. I'm learning a lot reading it...
21st Jul 2019, 11:35 am | #78 |
The BVWS Bulletin, Volume 26, Number 2 (Summer 2001) published a basic aerials article on page 26: "Installing aerials and earths - a forgotten skill?"
Unfortunately I don't have a scanner here or I'd post it on this thread. Last edited by Ian - G4JQT; 21st Jul 2019 at 11:42 am. |
21st Jul 2019, 1:04 pm | #79 |
Ian
It can be viewed on the BVWS website. Ill have a read of it later today. https://www.bvws.org.uk/publications...letin_26_2.pdf Mike |
21st Jul 2019, 1:19 pm | #80 | |
Many, many years ago, when I knew a lot less about electronics generally, I regarded that book as a valuable source of information. However, as the decades passed and my knowledge & experience gradually improved, I found many technical errors in that book, some of which were mistakes of a very fundamental nature; many were simple mis-prints. The book was obviously not proof-read prior to publication. I was amazed that Pat Hawker, G3VA, of all people had his name associated with that publication. I no longer own that book, so cannot point to the many errors that I found in it. Al. |
