Old 15th Jul 2019, 5:13 pm   #21
Welsh Anorak
Welsh Anorak's Avatar
Default Re: Revox A77 refurbishment advice please.
Like Michael, I've had a couple of those large axial caps fail. The symptom of the right hand one when it shorts is simply no capstan rotation with the voltage missing. Took me longer than it should have done to find as I was convinced the fault was on the power supply board.
Confession time - to avoid removing the whole switch board I cut the legs by the capacitor and soldered in the replacement axial component.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline   Reply With Quote
Old 16th Jul 2019, 9:03 am   #22
Michael Maurice
Michael Maurice's Avatar
If I'm charging for the job, I prefer to remove the board and solder the capacitors to the print. It saves the joint at the PCB track going dry jointed.
BTW, in the manual for my Korting tape recorder the manufacturer, the instructions for replacing parts on circuit boards is exactly as Glyn does.
Forum Moderator
Michael Maurice is offline   Reply With Quote
Old 16th Jul 2019, 3:44 pm   #23
Welsh Anorak
I normally don't do this as it does smack of a bodge, but in this case it was a 'get you home' repair, so I just changed the faulty capacitor - plus the inevitable RIFAs, of course.
Glyn
Old 16th Jul 2019, 11:58 pm   #24
Andrew64
Andrew64's Avatar
I have those caps on my list Michael & Glyn, 5 in total for that board + the trimmer, talking of trimmers, I can't find a Piher 20k for love nor money, plenty of 25k ones, I've tried at least a half-dozen sites and emailed Piher for a stockist, anybody know of somewhere?
Andrew
Illegitimi non carborundum
Andrew64 is offline   Reply With Quote
Old 17th Jul 2019, 10:14 am   #25
Michael Maurice
25K will be fine.
Forum Moderator
Old Yesterday, 10:13 pm   #26
Andrew64
Andrew64's Avatar
Thanks Michael - I'll get some of those on order.
Andrew
