17th Mar 2018, 4:32 pm | #1 |
Ril WW Resistors
Just been given a box full of high wattage WW Resistors. In amongst them were several Ril types. I've taken a picture of three of them - L to R - Type 42, Type 43 & Type 44.
The l/h one is designated "Ril Type 42", the middle one is a Rivlin Instruments Ltd Precision Resistor Type 43, & the r/h one is a hand written Ril 44. Google reveals that Rivlin made Inductive & non Inductive WW resistors. Other research reveals these 4 wire resistors can be used in a bridge format. Quite frankly, I cant remember coming across them before. If they were used in T/Eq or other circuitry, I've never had to replace any. Any info most welcome please ? Regards, David PS My apologies for picture's poor focus Last edited by David Simpson; 17th Mar 2018 at 4:34 pm. Reason: Picture quality |
17th Mar 2018, 4:56 pm | #2 |
Re: Ril WW Resistors
Have you tried using the macro setting on your camera, assuming it is a camera and not a phone?
17th Mar 2018, 5:24 pm | #3 |
What tolerance are they?
I have seen 0.025% ones in test equipment that I own. As Graham says a better photo would be good. |
17th Mar 2018, 5:37 pm | #4 |
Aye Graham,
I have made the effort, but it's a bit hit & miss. I use a Mintola digital camera which is now coming up 13 years old. It was 60th birthday present. So I guess the dual aging process, and usage, has maybe affected both the camera & myself. I'll maybe get it checked out at Jessops Aberdeen shop.(Whilst I visit Specsavers). Regards, David PS. Bye the way, I've just spoken with the chap who gave me the box of resistors this morning, & he says that, in turn, some years ago, he was originally given the box by a retired TV & Video shop owner who's retirement hobby was restoring vintage video equipment. However, he'd not used any Ril resistors himself. DS |
17th Mar 2018, 5:53 pm | #5 |
Sensing....Kelvin configuration?
Lawrence. |
17th Mar 2018, 7:14 pm | #6 |
I don't know about 0.025% tolerance, but some of the written resistances are either 0.015 ohms or 0.025 ohms. Tolerances on most are either written as 0.5% or 1.0%. The highest written resistance(on the black resin encapsulated type 43's) is 16.7 ohms. I've just the one resin enc. Type 42 & that is 0.025 ohms with 1.0% tol. The blue vitreous Type 44's are all 0.015 ohms with 1% tol.
The higher value ones seem to measure their resistances lengthwise, but at the ends they would seem to be less than 0.1 ohm between the wires. My cheapo RS LCR meter doesn't go below 0.1ohm. I'll maybe try my Marconi TF2700. Regards, David |
17th Mar 2018, 7:32 pm | #7 |
You may find that the resistances of the resistors are somewhat higher than the printed amounts but the amount of that resistance which lies between the two sense wire pickoff points may be more accurate. If so then they would be current sensing items rather than precision resistors.
18th Mar 2018, 12:23 am | #8 |
They sound like they might be amps range shunts from something like an early multi meter.
18th Mar 2018, 12:33 pm | #9 |
A local VMARS chum has suggested they might be used to compensate for metering lead resistance &/or shunt or multiplier lead resistance - for accurate calibration. Hence their low decimal point resistances.
For those resistors greater than 1 ohm - my cheapo RS LCR meter gets close-ish, but my AVO/Newlec DMM get much closer to 2 decimal points. Wish I hadn't flogged my Wayne Kerr B221 at times like this. An interesting wee exercise if nothing else. Regards, David |
