Old 10th Sep 2011, 4:58 pm   #1
tedzed1
tedzed1's Avatar
Default Wartime Civilian Receiver
Hello, not done a lot lately, so decided to sort the WCR out, once and for all.
purchased this about 2-3 months ago, a bit tatty, and the only noise it made was a 50 Htz mains hum,
so all stripped down, and all waxies changed, run up through my lamp limiter again, still humming, but would now just about receive a couple of stations, when a long piece of wire was inserted into the second (sensitive) aerial socket,
At least the Westector was OK,
So next Job was to replace the three mains smoothing elecrolytics, rated 8uf, they were replaced with three 10uf of suitable rating.
Powered up again, and the lamp limiter went quite bright, on rechecking my work, I had replaced on of the electolytics the wrong way round, this was quickly remedied, and the radio sprang into life. only needing a slight adjustment to the aerial coils to peak to maximum reception.
So onto the cabinet.
The cabinet and dial was showing it's age, so decided on a complete strip-down to the bare cabinet, this was then stripped of all old varnish, the sanded down, with progressively finer grade sandpaper, the final sand being fine grade wire wool and white spirit, the two horizontal pieces on each side of the front were then masked off, and sprayed, I know this is not original, but i fancied brightening it up a bit, ( I can here the purists shrieking in horror) and it seems to work quite well, the same treatment was also given to the wooden feet blocks, the case was then all reassembled, and treated to a few coats of brushed marine varnish, as it matched the original finish better than spraying it with lacquer I felt. the speaker cloth was scavenged from an alba 461 I had stored in the loft, it is of similar period.
So now for the dial.
Had a long hard think about various options on this, from a copy on photo paper or waterslide transfer, but decided to try a different approach.
So ordered a set of transfers from Letraset, and while I was waiting for them to arrive, set about sanding and spraying the dial.
three days later, the transfers arrived, so set to on applying them.
This was not as easy as I thought it would be, as if not careful, other transfers would apply themselves to the dial if I leaned on another part of the sheet that was in contact with the dial, and would need careful removal by scraping gently with a fingernail, It took me about two hours to do all the transfers, and I was glad to finish.
So all assembled it is now ready for some serious use. It maker as stamped on the chassis is U6, so I believe it is a G.E.C.
Thanks for looking
ID:	56064   Click image for larger version
ID:	56065   Click image for larger version
ID:	56066   Click image for larger version
ID:	56067   Click image for larger version
Cheers Paul.
tedzed1 is offline
Old 10th Sep 2011, 5:00 pm   #2
tedzed1
tedzed1's Avatar
Default Re: Wartime Civilian Receiver
The rest of the pictures
ID:	56069   Click image for larger version
ID:	56070   Click image for larger version
ID:	56071   Click image for larger version
ID:	56072   Click image for larger version
Cheers Paul.
tedzed1 is offline
Old 10th Sep 2011, 6:53 pm   #3
Al (astral highway)
Al (astral highway)'s Avatar
Tidy job, especially your work on the cabinet. What stations can you pull in now?
Al
Old 10th Sep 2011, 6:53 pm   #4
M0TGX Terry
That looks like a first class job, Paul. Don't worry about what the "purists" might say - it's your radio, so do it however you like!
I've been looking for one of these sets for some time, without success (we had one at home when I was (much) younger. Might post a wanted ad.
Well done
terry
Terry the Morganist
M0TGX Terry is offline
Old 10th Sep 2011, 7:15 pm   #5
Boom
That dial looks very good. Nice one
Boom is offline
Old 10th Sep 2011, 10:16 pm   #6
tedzed1
tedzed1's Avatar
Thanks for all the comments everyone,
hello Astral, it is MW only, and it has two sockets for the aerial, one is sensitive, the other is selective, it pulls in well if not better than some of my other sets when the antenna is plugged to sensitive.
Cheers Paul.
tedzed1 is offline
Old 11th Sep 2011, 12:36 am   #7
Phil G4SPZ
Phil G4SPZ's Avatar
I also have a GEC-built model. It is one of the most sensitive and nice-sounding sets in my collection. You have done a very nice restoration job on yours, well done!
Phil
Phil G4SPZ is offline
Old 11th Sep 2011, 5:33 pm   #8
A real good job with the dial (and the rest)
Old 11th Sep 2011, 8:34 pm   #9
HamishBoxer
HamishBoxer's Avatar
Superb!
HamishBoxer is offline
Old 12th Sep 2011, 7:38 pm   #10
Hybrid tellies
Hybrid tellies's Avatar
Really nice job, I bet it sounds good.
Simon
BVWS member
Hybrid tellies is offline
Old 15th Sep 2011, 11:14 pm   #11
Tim
Tim's Avatar
Nice job.
Tim is offline
Old 16th Sep 2011, 8:45 am   #12
SeanStevens
SeanStevens's Avatar
That looks really nice - certainly brigher.
It looks like ALBA only had one kind of speaker material! Mine has the exact same pattern.
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
