17th Jun 2011, 4:32 pm | #1 |
When I'm 64 - An Alba Story
I almost left this poor beast at Frome last week. It looked sad and scruffy - not really a beauty. I popped the back open and was shocked by the mixture of large valves tucked inside. I teetered on walking away, but bought it out of pity.
Armed with a Variac and a prevailing wind................. Motorboating of the highest order. I got a few stations by winding the volume right down - but definitely instability. I checked the case carefully and found a woodworm hole - so I popped the chassis out and the case got treated. We visited Ian - The trader sheet had an error on it - but after identifying that, we changed a few usual suspect capacitors to no avail - motorboating just would not go away. Ian and I sourced an EF39 equivalent - popped it in and - PERFECT! All sorts of stations appeared - after lining it up it sounded amazing. The case was in reasonable condition till I got to it - using a scraper to remove varnish/lacquer I found no WW holes visible on the outer of the case - I noticed that the lacquer fell of the upper wood veneer - but clung hard to the bur walnut. It took longer to clean off than I expected. The case had matt black painted ends when I got it. I don’t know if it left ALBA like that, but it looked nice as it was. I repainted these, and then decided that the other wood bits and pieces (being brown) might look better matching the ends. The fact that I had no matching brown paint did not affect my decision. After removing the huge speaker, the speaker cloth came off easily (old glue) and was noticeably faded on the outer side. I gave this a light wash and left it to dry flat on a flagstone. When dry, I popped this back in ‘back to front’ and spend 10 minutes aligning it as the pattern showed up the slightest deviation from horizontal. The case got 3 coats of Danish oil - not much else. I like the satin finish over high gloss. After that, speaker and baffle back in - chassis back in - soldered the speaker up and photographed for the forum! This is a gorgeous sounding radio - I wonder why ALBA went from this to the cheap end of the market?
There are only 10 types of people, those who understand the binary system, and those who don't. |
17th Jun 2011, 4:53 pm | #2 |
Re: When I'm 64 - An Alba Story
Well done - smashing job!
17th Jun 2011, 7:09 pm | #3 |
Lovely job.
17th Jun 2011, 8:16 pm | #4 |
Nice Job Sean.I've never seen one of those before.
Frome chattels auction does come up trumps from time to time. I've only been successful once, and as it's on a weekday and don't have any more room for radios I don't visit any more.
17th Jun 2011, 8:47 pm | #5 |
Very well done, What a lovely example of fine British manufacturing. A good solid chassis in a good solid cabinet with nice finish.
Bet it sounds great? I love these British wooden cased sets Paul. |
17th Jun 2011, 9:05 pm | #6 | ||||
The Alba of that beautiful radio has little or no connection with today's Alba, an Argos brand. Alba died in 1982.
Somewhere along the way Bush and Goodmans died too. Alba, Bush and Goodmans have been nothing more than badges for over 20 years. Quote:
See http://en.wikipedia.org/wiki/Harvard_International |
17th Jun 2011, 9:23 pm | #7 |
Now that IS a wireless.
Looks brilliant. Well done. Al
I won't tell you how I discovered that. |
17th Jun 2011, 9:34 pm | #8 |
What a lovely set, well done Sean When I was younger, without knowing the company's early history as I do now, all I can remember of Alba is a name synonymous with cheap tat. It's good to be reminded that name was once on sets like this.
PS: Sean just looking on the Radio Museum site at the 474, it did seem to have black sides. Andrew
Invisible airwaves crackle with life. Or they should do. BVWS Member |
17th Jun 2011, 10:29 pm | #9 |
Cracking restoration. Well done. Love to have that in my collection!
Bob W
Radio Tircoed - Working for the Community |
18th Jun 2011, 10:45 am | #10 |
Alba isn't a make that attracts me - but after seeing this set I'm going to have to rethink!
Lovely job on the cabinet, nice looking chassis. I like the string pointer mechanism on the wavechange switch. I take it that it uses an octal valve line-up? Well done! |
18th Jun 2011, 11:12 am | #11 |
Very nice job, it seems to be a model 473 from 46/47. I just purchased a radio from the same period but no back and hence no maker and it is similarly solidly built with a geared slo-mo drive. Considering these were built post war during rationing and shortages I guess they would have been a real luxury item.
18th Jun 2011, 11:47 am | #12 |
Would liked to have seen more of the chassis, a very smart radio and what looks like a ten inch loudspeaker in good condition so must sound very good. I have only seen one other radio with a speaker of this size, can't recall the make though it had a metal mesh grill. Well Done.
18th Jun 2011, 12:03 pm | #13 | |
It's often been said that many companies' build quality was at its best in the early post-war years, as it took a while for the standards demanded by work for the military to lapse back to ordinary cost-conscious domestic ways. Having said that, early '30s Albas are very well put together too, and late '30s ones not too bad at all. The 473 (or 474 if AC/DC) is a nice heavy job that also appeared in a slightly different cabinet under the Aerodyne brand. Regards, Paul |
18th Jun 2011, 12:04 pm | #14 |
Looking at that excellent cabinet,was it just a paint scraper you used?
David |
18th Jun 2011, 1:40 pm | #15 |
Nice job.
Cheers. |
18th Jun 2011, 1:54 pm | #16 |
Now that's a nice radio and an excellent job, I like the finish too.
31st Aug 2011, 4:37 pm | #17 |
In reply to HamishBoxer - I scraped the finish off using (mainly) blunt Stanley blades. I don't have a real scraper.
SEAN
31st Aug 2011, 9:34 pm | #18 |
Brilliant job Sean.
I did one of these for a local lad a few weeks ago and it worked beautifully, sensitive, loud and a good tone. They are well worth looking out for.
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member |
31st Aug 2011, 10:26 pm | #19 |
Very nice well done indeed the Danish oil gives a lovely finish I must try it on my next restoration . Mick.
1st Sep 2011, 2:31 pm | #20 |
An amazing restoration job here,congratulations. Just loved looking at the station names and thier places on the dial.
Simon BVWS member |
