27th Feb 2019, 9:37 am | #21 |
Re: Dummy Load possibilities
Engine oil on sale today has all sorts of additives which are not good in this application, some rather aggressive detergents and such.
Someone in an ARRL publication did a lot of work on this and found apart from intended transformer oils,'Turbine oil' is good..... The stuff Aeroshell flog you to top up the lubricant tanks on jet engines. In ARRL handbooks of your there are several designs for using these resistors and even one with flared ground cones around the resistor, nit just to connect to the far end but also to create a matched transmission line down its length, making the big resistor good to UHF David
27th Feb 2019, 2:59 pm | #22 |
Bird dummy loads (which have a similar shape resistor, but carbon film on ceramic tube, not solid carbon) use a silicone oil. I have found a note that says it has an average kinematic viscosity of 20 cSt (centiStokes, a cgs unit) and that Dow Corning 200/20 is suitable, but rather expensive.
That should give a guide as to what else would be suitable. |
27th Feb 2019, 4:20 pm | #23 | |
B
27th Feb 2019, 4:48 pm | #24 |
What about the oil in domestic oil filled radiators? I've no idea what it is but Wikipedia says,
"The oil has a relatively high specific heat capacity and high boiling point. The high specific heat capacity allows the oil to effectively transfer thermal energy from the heating element, while the oil's high boiling point allows it to remain in the liquid phase for the purpose of heating, so that the heater does not have to be a high pressure vessel." Hopefully it would be pretty innocuous in case of leakage having been made specifically for domestic use. John Last edited by John M0GLN; 27th Feb 2019 at 5:06 pm. |
28th Feb 2019, 11:34 am | #25 | |
My dummy loads have nearly always been lamps or a string of. I'm only thinking of making this because I've had the resistor lying around for many years. At my low frequencies I could probably even calibrate it using AC mains with near enough accuracy. At the moment I don't even have an HF transmitter until I make one so that might not be too soon. Jim |
