19th Jun 2014, 3:50 pm | #41 |
Re: Fluke 8600A Fault
In the battery-only version there's no reservoir capacitor in the battery charger. If you add one it may blow up the power supply. If you feed +5 V (China wall wart) into it it should work just fine.
Incidentally, found the manual at Mrs. Tanya (or is it Miss?). Tjerk, 9ZZ Last edited by PE9ZZ_JO22KI; 19th Jun 2014 at 3:52 pm. Reason: added download link |
19th Jun 2014, 10:39 pm | #42 | |
Then it is over. It kills a lot of unobtainable IC´s I know,because I learned the hard way. Jard N |
20th Jun 2014, 6:29 am | #43 |
Thanks for the replies everyone. I understand that running the current power supply without the batteries is going to fail. I was just wondering if anyone had replicated the original mains circuit using the Fluke configuration. Comparing the two different versions, the parts count is low for the AC only supply, but replacing the transformer may take a bit of doing. I'm wondering what would be more cost effective, replacing the batteries with new ones, or replacing the power supply.
What else am I missing here? |
20th Jun 2014, 11:48 pm | #44 |
Just fit 4 good "D" cells with clean contacts. I used an 8600A extensively for field work in the '70s and it served me well.
The only problem I had with the 8600A was that unlike the 8000A, there was no visual indication that it was charging. A dead socket in a hotel room once caused wasted time on the job on the following day. Leon. |
21st Jun 2014, 8:52 pm | #45 |
4 good D-Cell NiCad's will probably cost more than the meter is worth!!!! (£8 per cell last time i tried to get some)
The charging circuit would destroy NiMh in a very short time! A cheap walwart adaptor could be purchased for about £5, or a decent homebrew linear for a little more. I have several of these meters, and replace the D-Cells with a D-Cell adaptor which holds two AA Nicads, which can still be found for decent prices. These regulate and smooth out the AC supply well, with the added advantage of short term portable use (1 hour). peter
SPECIALIST.....Knows everything about nothing EXPERT..........Knows nothing about everything |
21st Jun 2014, 9:52 pm | #46 |
D size NiCad packs are still used in emergency lighting units. 5 and 6 cell packs can be found on Ebay for around £10. I cannot vouch for the quality and age of these batteries or even how easy it would be to split them apart to make new combinations but would be worth a punt.
Al
I won't tell you how I discovered that. |
6th Jul 2014, 7:44 am | #47 |
6th Jul 2014, 1:15 pm | #48 | |
Unfortunately NiMH batteries can't be charged this way. They don't like being trickle-charged to more than their capacity, so the charger needs to be able to detect when the battery is fully charged. This isn't trivial with NiMH batteries: you either have to detect the rise in temperature of the battery, or spot that its terminal voltage has started to fall slightly. If the charger doesn't do this, the batteries will just sit there getting hot and they will cease to be batteries pretty quickly. Modifying the Fluke circuit to spot this end-of-charge is a big job. Chris
6th Jul 2014, 6:54 pm | #49 | |
Would you happen to have a picture of the D-Cell adaptors you are referring to? I can find plenty but none with the tabs necessary to mount in the meter. Or, are you using some other means to connect them? Thanks again for the time and attention. cheers, Paul |
6th Jul 2014, 6:58 pm | #50 | |
I was wondering if any of the available smart NiMH charger chips would be suitable in this application. Must confess I am intrigued about the possibility, but also conscious that this project is probably getting to be more complicated than it is worth. If I can find the adapters Peter is referring to, will probably go that route. Thanks again. cheers, Paul |
6th Jul 2014, 8:35 pm | #51 | |
I've got a whole load of 8600As in frequent use and I'm fond of them, but they do their jobs tethered to the workbench. Chris
6th Jul 2014, 10:23 pm | #52 | |
Also a picture showing them installed in the meter. No need for any tabs! I did originally try cutting open some emergency lighting D-Cell packs, but they don't split!! The ones I had are three D-Cells fabricated in a single tube! Like three cells in a car battery in a single case. I tried splitting them, but it destroyed the cells. Peter
7th Jul 2014, 3:07 am | #53 |
Thanks Peter. I see now what you mean, but am wondering the source of the metal contact strips you show in the second picture. The dead batteries in my meter had tabs, so if the contact pieces are part of the original setup, I don't have them.
Paul |
7th Jul 2014, 7:50 pm | #54 |
My meter is standard, no mods!
I have four of these, and they were designed to take regular D-Cell nicads. The Metal tags are soldered to the pcb, and pass through the two battery clamps, which hold them tight against the batteries. I have four of these meters and they are all the same (and another 6 in the garage waiting to be looked at!!!) Do you still have the battery clamps, or were these removed also? Maybe yours is an earlier or later version, and fluke changed the design? Peter
7th Jul 2014, 9:25 pm | #55 |
Paul
Just had a look in one of my battery Fluke 8000 DMM's (very similar to an 8600, but only 3.5 digit) with a smashed case (I was looking at removing the parts you needed) and noticed that this uses tagged D-Cells, as you describe. Looks like there ARE at least two different variations. So I will need to look for a similar solution as you are looking for. Fortunately the battery holding clamps still used, so securing the batteries is not a problem. I think I will be looking at a similar solution using the D-Cell adapters, and soldering flying leads to them. Peter
10th Jul 2014, 9:17 pm | #56 |
Peter,
Thanks again for all the help. Yes, the battery holders are in place. I don't know if the meter originally came with tabed batteries of they were a subsequent repair/modification. I have a set of D-Cell NiCd with tabs enroute. Will try those and see how long the batteries last. If you come across a source for the contact strips please let me know, because I like your solution better for the long run. Thanks again. cheers, Paul |
