Old 8th May 2023, 10:25 pm   #1
Ferguson 2000
Default R1155 transformer core stuck
Can anyone suggest a way to soften the locking compound used on this core adjuster which is Bakelite in a Bakelite surround.
I have tried switch cleaner, very thin oil, acetone and soaking in boiling water but it has not moved 0.01mm.
All suggestions gratefully received.
ID:	277921   Click image for larger version
Best wishes,
Geoffrey.
Ferguson 2000 is offline
Old 9th May 2023, 1:25 am   #2
FrankB
Default Re: R1155 transformer core stuck
I had a problem decades ago with 2 variable transformers not adjusting. Turned out the lube they used on the Bakelite insulating rod swelled it up. I finally used a punch and light hammer to free it. Sanded it down to correct diameter and cleaned all the old lube off and used silicone grease for the lube.
I suspect this may be the case on your core, or the core was sealed in by an epoxy. If it's a "do or die" you might try a small pencil torch to heat it up. or the hammer & punch method. Risk is it could cause damage to the unit.
Loctite corp may make a solvent to remove thread lock and that might be worth a try also.
FrankB is offline
Old 9th May 2023, 8:03 am   #3
HamishBoxer
HamishBoxer's Avatar
Does it really need adjusting ?
HamishBoxer is offline
Old 10th May 2023, 11:24 am   #4
Ferguson 2000
Hi to FrankB and HamishBoxer,
Thank you for your replies, I was hoping that someone had had this problem before and had found a suitable solvent, it would seem not.
I do need to adjust the core in order to balance the DF loop.
Best wishes, Geoffrey.
Old 10th May 2023, 11:51 am   #5
HamishBoxer
Understood Geoffrey.
Old 11th May 2023, 10:42 am   #6
bill knox
Hi
I have several R1155s, where is this capacitor located, I do not recognise it at all, but knowing how the AM wanted everything on these receivers locked tight they may have used Shellack (not sure if I have spelt that right) if so Methylated Spirits may work.
Let me know its location and I will look and see if I have one.
Regards
Bill
bill knox is offline
Old 11th May 2023, 1:11 pm   #7
Station X
Station X's Avatar
I don't think capacitors have been mentioned.
Graham. Forum Moderator
Station X is offline
Old 11th May 2023, 4:52 pm   #8
ms660
ms660's Avatar
Just for info for anyone that's interested, the DF Loop coils in the info I'm looking at in AP1186 Vol. 1 (Revised) are L4, L5 & L6, their top side chassis layout locations are Db, Da & Ca respectively.
Their trimmer capacitors are C57, C58 & C59 respectively, their bottom side chassis layout locations are Ah (C57 & C58) and Ag (C59)
Lawrence.
ms660 is offline
Old 22nd May 2023, 2:55 pm   #9
Ferguson 2000
Dear Bill, Graham and Lawrence,
Thank you for your replies.
It is one of the DF coil adjusters that is stuck solid - L4 but L5 is similar.
If I come up with a solution I will post it.
Old 22nd May 2023, 11:33 pm   #10
bill knox
Hi My mistake where I got "capacitor" from I don't know.
Where in the r1155 is this part fitted, I have several r1155s and if possible I can remove it
Regards
Bill
