30th Sep 2014, 7:58 am | #1 |
Valve chain current?
What is the total current drawn from four valves running at 0.3 amps each?
Mike. |
30th Sep 2014, 8:05 am | #2 |
Re: valve chain current
If they're in series (as implied by "chain"), the total current is 0.3A. Only the voltage is different for the chain and for an individual component thereof. If they were in parallel, the total would be 1.2A (i.e. 0.3A x 4), and the voltage across each component and the whole would be the same.
30th Sep 2014, 8:08 am | #3 |
Assuming we're talking about them being in parallel, 0.3 x 4 = 1.2 A.
Mike. |
30th Sep 2014, 10:14 am | #4 |
Re: Valve chain current?
Yes they are in series. Thanks for help that makes my calculations for a voltage dropper make sense now.
Mike. |
30th Sep 2014, 11:12 am | #5 |
It would be rare for four 0.3A valves to form a series heater chain. Are you sure?
30th Sep 2014, 11:19 am | #6 |
My Philco U427 peoples set uses a .3A heater chain, What set are you talking about?
John. |
30th Sep 2014, 11:22 am | #7 |
Hi John,
Its a Bestone USA midget radio. Information is so limited that I am drawing the circuit out. |
30th Sep 2014, 11:44 am | #8 |
I should have added there is also a Barretter and scale bulb in the chain.
Just seen your last post, I very much doubt you would have a Barretter in your chain. John. |
30th Sep 2014, 12:26 pm | #9 |
If it's an American midget set, you would be better using a capacitive dropper. There will be considerable heat from a resistive dropper and a .3A heater chain whereas there will be no additional heat with a capacitive type. It all depends on space availability but in this case I would say that the capacitive type is the better option.
Check Paul's calculator for a suitable value. http://www.vintage-radio.com/repair-...per-calcs.html If you haven't seen it, right at the bottom of the page there is a spreadsheet you can download that does all the calcs for you.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 30th Sep 2014 at 12:32 pm. |
30th Sep 2014, 2:29 pm | #10 |
An American radio is more likely to have a 150mA heater chain, unlerss it was intended to run from 32V DC farm supplies.
30th Sep 2014, 7:01 pm | #11 |
If you have more than one US set best to get a 110V transformer, cheap enough and a good one would give an isolated output.
