24th Sep 2014, 12:46 pm | #1 |
L67bg
I need the base details for this valve/ballast. L67BG Any link to data would be handy.
Mike. |
25th Sep 2014, 11:49 am | #2 |
Re: L67bg
Hello,
There is this for the L67B but there are other L67s with other suffixes with different connections. www.radiomuseum.org/tubes/tube_l67b.html Yours Richard |
25th Sep 2014, 1:08 pm | #3 |
Re: L67bg
Thanks Richard,
That is the one. I did a search on Radio Museum but came up with zero. I am managing to do without it at the moment, as I am running the heaters via a pair of high wattage wirewound resistors, but will revert to the valve if and when I can find one. This valve seems to be a USA quirk. I don't know if they were ever used over here. I did find out that the number of the valve refers to voltdrop on some of them, after they standardised their ballast tube numbering system, but I don't think that applied to the one above, as the volt drop needed is around 48 volts. The valve in question has a crack in the ceramic material on which the resistance wire is wound and is O/S. Mike. |
25th Sep 2014, 10:36 pm | #4 |
Re: L67bg
O/S?
O/C or U/S perhaps?
26th Sep 2014, 7:50 am | #5 |
Re: L67bg
No Oh S**
