Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 30th Apr 2019, 10:07 pm   #1
Cobaltblue
Cobaltblue's Avatar
Default Wanted source of small speaker for walkie talkie
Looked in the usual places but they are all shown as 36mm
The original seems to be 1.25 inches or 32mm give or take a smidge.
It won't be easy to fit anything bigger as it fits into a moulding.
16 ohms any pointers ?
Mike T
ID:	182192   Click image for larger version
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 1st May 2019, 6:06 am   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: Wanted source of small speaker for walkie talkie
How deep Mike?
Andy
Old 1st May 2019, 6:34 am   #3
Nickthedentist
Nickthedentist's Avatar
I repaired mine with one from a defunct satnav.
Nickthedentist is online now
Old 1st May 2019, 8:15 am   #4
Cobaltblue
Cobaltblue's Avatar
Originally Posted by Diabolical Artificer View Post
How deep Mike?
Andy
Hi Andy I don't have it to hand but it's about 6mm I will measure it lunch time.
Hi Nick yes I have been hunting around but most I have found so far are too big to fit
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 1st May 2019, 8:18 am   #5
Nymrod121
Nymrod121's Avatar
This any good, Mike? It's 8mm deep.
If so. PM me your address and I'll post it asap (no charge )
Guy
ID:	182210   Click image for larger version
Nymrod121 is offline
Old 1st May 2019, 8:31 am   #6
crackle
crackle's Avatar
I thought I might have one but neither are correct, 1.5 inches and 1 inch so sorry.
Mike
BVWS Member
The KB Museum
My collection in the Radio Museum
crackle is offline
Old 1st May 2019, 9:06 am   #7
Cobaltblue
Cobaltblue's Avatar
Guy
Hi Guy that's very generous but the diameter is just too big.
Thanks Mike yes it's a very odd size I may have to fit a smaller speaker I will give it a day or two
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 1st May 2019, 10:06 am   #8
Nickthedentist
This one from Rapid?
https://www.rapidonline.com/kepo-kp3...z-1-5w-51-7387
Appreciate it's 8R, but...
Nick.
Old 1st May 2019, 10:08 am   #9
Nickthedentist
Or even: https://www.ebay.co.uk/itm/Replaceme...gAAOSwRaFcd3e9
Old 1st May 2019, 11:56 am   #10
electronicskip
electronicskip's Avatar
This one on Amazon is 30mm dia by the looks of it.
https://www.amazon.co.uk/Miniature-S...ateway&sr=8-12
electronicskip is offline
Old 1st May 2019, 3:28 pm   #11
Cobaltblue
Cobaltblue's Avatar
Thanks for all the suggestions guys looks like I will have to use 8 ohm with a series resistor.
I am sure it will make little difference.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 2nd May 2019, 10:31 am   #12
OscarFoxtrot
OscarFoxtrot's Avatar
I think for someone's loudspeaking telephone we found a headphone driver of the right size and impedance. Might be a useful search term.
OscarFoxtrot is offline
Old 2nd May 2019, 11:35 am   #13
Hammonds
Hammonds's Avatar
Hi Mike
I've got one which is 28mm diameter by about 4mm deep, 8 ohm if that's any good. FOC.
Dave
Hammonds is offline
Old 2nd May 2019, 4:42 pm   #14
TonyDuell
That sounds like my QWERTYphone.
It was certainly suggested that a headphone driver would be worth considering. However I found the exact speaker, misdescribed, on Ebay. I have no idea what it was originally used for.
When I say 'misdescribed', the impedance of the one on Ebay was quoted as 16 ohms, which was lower than I really wanted but I decided that it would be easier to modify the electronics than the case parts. When it came, the DC resistance was around 25 ohms which was ideal... So I was _very_ lucky.
Of course this doesn't help with the current problem.
TonyDuell is offline
Old 2nd May 2019, 5:11 pm   #15
Electronpusher0
Hi Mike,
you are welcome to this one if its any good, still fitted to a small walkie talkie case, Motorola YTR446.
16 ohm, seems about the right size.
Peter
Electronpusher0 is offline
Old 2nd May 2019, 8:14 pm   #16
Cobaltblue
Cobaltblue's Avatar
First thanks to everyone for all your efforts.
Peter I will drop you a PM the Walkie Talkie I am trying to fix is also a Motorola
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 4th May 2019, 2:58 pm   #17
Cobaltblue
Cobaltblue's Avatar
The speaker Peter sent has arrived but is 36mm so doesn't fit
I wish to say a big thank you to Peter for his efforts.
As I said before it fits into a moulding so not at all easy to fit a larger speaker.
I have ordered three 8ohm ones from China for 99p so fingers crossed.
In the mean time if anyone has a speaker 16 ohm no more than 32mm diameter and 5mm deep I am still looking
It comes from a Motorola TLKR T40
These are only about 40 a pair new I fished these out of the WEEE bin in the lab at work.
I hate things being disposed of prematurely.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 11th Jun 2019, 7:40 pm   #18
Cobaltblue
Cobaltblue's Avatar
Just to finish this one off finally the speakers arrived from China and I fitted one with 10 ohm resistor in series. It's a perfect mechanical fit and although a wee bit quieter seems to work fine.
Just 99p inc postage
All ready for the grand children to play with
This thread can be closed.
Cheers Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 11th Jun 2019, 7:51 pm   #19
AC/HL
AC/HL's Avatar
From a fellow grandchild minder, "a wee bit quieter" is an added bonus
Bill, BVWS member
AC/HL is offline
Copyright ©2002 - 2019, Paul Stenning.
