Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Reply
Old 3rd Apr 2019, 6:43 pm   #1
don200002
don200002's Avatar
Default GEC (Gecophone) BC761 choke required
Hi all
I have restored this radio and use it on a daily basis. The original fault was an open circuit anode choke BC761. The set is working with an old smoothing choke that I happened to find among my box of things that might come in handy sometime. It would originally have required a high impedance speaker but works quite happily with a Bush output transformer and low impedance speaker.
The problem is that the choke has a marked effect on the output frequency range, having tried several chokes with various results it would be nice to get an original. I think these chokes were also used in some Cossor sets from the same era(1930).
Any help would be appreciated and a high impedance speaker would be useful.
I've been looking for a speaker cabinet of the same period but I'm beginning to think it would be easier to make one as they are very expensive on the auction sites.
The model number is BC3140 and I think you will all agree it's worth trying to get it back to original spec.
Many thanks in advance, Don.
Name:	gecophone bc 3140.jpg
don200002 is offline   Reply With Quote
Old 3rd Apr 2019, 7:26 pm   #2
Ed_Dinning
Default Re: GEC (Gecophone) BC761 choke required
Hi Don, if the original choke is available it could be rewound.
I have also grafted a modern output transformer into a vintage case so that a modern speaker (in an old cabinet) could be used with a 20's set.
Nice looking set by the way.
Ed
Ed_Dinning is online now   Reply With Quote
Old 3rd Apr 2019, 8:18 pm   #3
don200002
don200002's Avatar
Hi Ed,
I have not removed the old choke I think the whole radio was built around it. That should be my next move as it could be a broken wire at the terminal end, unfortunately I can't get at it without dismantling most of the radio. Yes an output tx could be fitted in the speaker case. There is very little space inside the cabinet, not even enough to fit my choke so I'll have to bite the bullit at some stage. Thanks for your input, Don.
Old 3rd Apr 2019, 8:34 pm   #4
Cobaltblue
Cobaltblue's Avatar
I don't think Cossor chokes are that similar I have a BC3140 and an awful lot of Cossor sets.
They are bit of a pig to work on.
As was the fashion of the day the only thing easy to change are the valves through cover and hatch on the back.
Cracking set.
Picture of mine attached
Cheers Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline   Reply With Quote
Old 10th Jun 2019, 1:47 pm   #5
don200002
don200002's Avatar
At long last I have removed the choke and managed to get it out of it's case. The whole thing was set in pitch so not easy. However is is open circuit and I do need a replacement or a rewind. I forgot to mention before that the wooden valve access door was broken in half and while I was attempting to repair it my neighbour came across and said "don't bother repairing that I'll make you a new one" I have attached some pictures of the broken and remade door and when re-polished and fitted.
Over the last couple of months I have picked up an old PYE moving iron speaker which works very well with the set, and the luckiest find this year a BTH horn which also works fine, not exactly Hi-Fi but in keeping with the Gecophone.
Any help with the choke would be appreciated it's the final part of the puzzle.
Don.
Name:	Gecophone rear cover.jpg
ID:	184818   Click image for larger version
ID:	184819   Click image for larger version
Name:	Horn original.jpg
ID:	184820   Click image for larger version
Name:	Horn Speaker.jpg
ID:	184821   Click image for larger version
Name:	Gecophone Choke.jpg
Old 10th Jun 2019, 3:12 pm   #6
don200002
don200002's Avatar
Thanks Ed for your PM
More pictures attached
ID:	184826   Click image for larger version
Old 10th Jun 2019, 6:43 pm   #7
Ed_Dinning
Hi Don, that should rewind easily enough, but will need cheeks added. It can then be rewound with grade 2 wire without any interleaving paper.
It can be re-potted with paraffin wax, much less messy.
Ed
Reply
Copyright ©2002 - 2019, Paul Stenning.
