25th May 2020, 8:16 pm | #1 |
Steepletone 5002D
Hello Everybody.
This is my first post on this site, I am a newbie. I have just got a Steepletone 5002D, nothing seems to work on it. I took of the back case, and had a look inside, to me I was surprised to see how clean it is. I plugged her in and I got my electrical light stick to see if power is inside the player, and there is. but now I am stuck. I have no idea what to do now, the needle is also broken off. is the any one out there who can help me. would love to see it working again as I had one when I was only 14 years old, now 49. thank you Alan |
26th May 2020, 7:51 am | #2 |
Re: Steepletone 5002D
I'm not at all familiar with this record player - which I assume that's what it is. I deduce it's from 1985, so it may use a very late BSR deck and for these a stylus can usually be found. We will need external and, if possible, internal photos please. BTW, what's an "electrical light stick"?
Edward. |
26th May 2020, 8:11 am | #3 |
26th May 2020, 8:20 am | #4 |
The inside
26th May 2020, 8:29 am | #5 |
These are some pictures of it.
26th May 2020, 8:42 am | #6 |
So I think their was two types made, looking at the speaker design it looks like mine is the earlier model.
26th May 2020, 8:58 am | #7 |
Obvious things first. Have you checked the fuse shown in your first picture? The brown wire of the mains lead is connected to it.
If you're going to get far with fixing this you're going to have to get a testmeter. These can be purchased from ScrweFix etc.
26th May 2020, 9:11 am | #8 |
Many thanks to the OP for these clear photos. We will also need to see a close up of the cartridge and of the broken stylus - does it have any markings on it like "SC11M"?
Edward. |
26th May 2020, 9:51 am | #9 |
Have you tried lifting the arm then gently moving it to the right to start the turntable spinning? Some units switch on like that.
26th May 2020, 9:59 am | #10 |
Yes. a switch can be seen in post #5 picture 3 and it looks like it's activated by the tone arm.
It also appears that the speed switch is set to the '0' position rather than 33 or 45. It is of course purely mechanical, moving the idler wheel to contact the correct step on the motor pulley.
26th May 2020, 11:09 am | #11 |
This is the one that has flashing disco lights in the speakers, do you have them too? Be very careful about how you connect it up if not, as you can ruin other speakers if you connect them up wrongly. IIRC these have 8 pin DIN connectors (but it's been 30 years since I last saw one!)
Do as suggested above re: arm to power up and let us know if it comes on. And of course see the fuse. I cannot recall what stylus it uses. A vague memory suggests it might have been a Tetrad or Sanyo N3C or Panasonic EPS14 - pics would help. edit: just seen post 6, which confirms what I mentioned earlier. Just don't try connecting other speakers to it!
Regards, Ben. Last edited by ben; 26th May 2020 at 11:17 am. |
26th May 2020, 11:56 am | #12 |
the cartridge looks like one of the versions of a bsr sc7
26th May 2020, 2:24 pm | #13 |
WOW, I must what a fantastic response from all of you, this is the broken stylus.
Also what size fuse should be in the plug 13 Amp or 3 Amp? |
26th May 2020, 2:36 pm | #14 |
3 Amp. The chances are the player's internal fuse is rated at a lower current than this. Check the label on the internal fuse.
26th May 2020, 2:36 pm | #15 |
This is the glass fuse inside the machine, what size is this ? I can see V250 I think but it also has some over writing too hard to see
26th May 2020, 2:39 pm | #16 |
One end says 250V the other end says S (Slow Blow) followed by 50 and another figure under the solder blob. Possibly 500mA (half an Amp).
26th May 2020, 2:55 pm | #17 |
26th May 2020, 2:57 pm | #18 |
Is it sensitive enough to detect current in the yellow wires connecting the mains transformer secondary winding to the circuit board?
26th May 2020, 3:06 pm | #19 |
The table at the bottom of this page: https://www.slimlab.net/mirror/fusec...usecolours.htm
Seems to show a variation of the standard colour code, but that black band would mean 63mA?. 630mA would be a modern standard value. |
26th May 2020, 3:51 pm | #20 |
Been a long time since I have seen colour coded bands on 20mm glass fuses, good to see the website listing the colour codes.
But the website information does not make much sense with the fuse in question. It says the wide band (blue) is Normal rating, slow blow is listed as green ? I am more familiar with the European fuse letter designations where T (German Trage) = slow blow. 500mA according to the website would be Green Black Brown. I agree it most likely is 500mA but the colour codes just confuse in this case. |
