Old 18th Jul 2021, 4:10 pm   #1
kirstyd
Default Acos GP91-3sc
Hi all
i have four of these and 1 GP91-1sc .They all work but they all have the same fault [droopy flag syndrome ] that's what i call it .has anyone any tips on how to fix the problem without taking the cart apart [I usually put a small elastic band on to hold it up but its not a good fix .Also what's the difference between the 1sc and the 3sc ?.
ID:	237907   Click image for larger version
kirstyd is offline
Old 18th Jul 2021, 4:37 pm   #2
Edward Huggins
Default Re: Acos GP91-3sc
Wow! The Acos GP91//3sc is a (and by now very rare) HIGH-OUTPUT, stereo-compatible cartridge giving c.600mV and are worth their weight in gold. If fully working, these can sell for aound 40-00. The 1sc gives around 150mv. As long as the stylus is vertical, the "droopy" flag is just a nuisance. This might be fixed by using just a very small dab of Evostik or similar contact adhesive.
Edward.
Edward Huggins is offline
Old 18th Jul 2021, 5:19 pm   #3
ben
ben's Avatar
I suspect someone has tried to remove the whole stylus assembly as with a BSR or Philips, say. Is the metal retaining clip rivited down? Post a pic if unsure.
Ben.
ben is offline
Old 18th Jul 2021, 5:22 pm   #4
kirstyd
Thanks for that Edward .As i said they all work very well just the problem with the flag .I have one fitted to my Bush Rp 50 .On that one i cut best part of the flag off leaving just enough to turn it over .bit drastic i know but it worked and back when i did it i didn't know any better
kirstyd is offline
Old 18th Jul 2021, 7:08 pm   #5
Trevor
I used to sell these used loads of them and was very satisfied with the resulting sound !
I think they were about 3 each at the time early 70,s
I used them with a home made passive mixer going into a Selmer 100 watt valve Pa amplifier
Golden days
Trevor is offline
Old 18th Jul 2021, 7:17 pm   #6
BRASSBITS
as Ben above says Is the metal retaining clip present?
its a torsion spring that holds the stylus by the flats at the end of the stylus many people remove it to change the stylus and cant get it back on
then end up with the droopy flag
BRASSBITS is online now
Old 18th Jul 2021, 8:09 pm   #7
toshiba tony
toshiba tony's Avatar
I liked these cartridges. They were pretty tough and were used in the cheaper DJ consoles frequently. They were decent at the top end and would play discs some others wouldn't.
toshiba tony is offline
Old 18th Jul 2021, 9:39 pm   #8
Trevor
In the Place Hanley stoke on trent I used these with Thorens Td124 sme arms intil i uprated to Shure M3D ghis would have been 1968 -1970 not low end gear I will admit
Trev
Trevor is offline
Old 19th Jul 2021, 7:36 am   #9
Edward Huggins
Just to say that these are not a good match to the amplifier in a Bush RP50. Your Acos GP91/1sc would be better.
Edward.
Old 20th Jul 2021, 1:00 pm   #10
kirstyd
Yes i know Edward .the old Bush has been around for 52 years .Its not one of bushes best offerings in fact as far as Bushes record players go it must be the worst but it i was delighted with it back in 1968 .the Acos 93 was fitted around 1972 when the original BSR packed up and i have to say the sound quality is vastly improved although the volume can only be turned up to around number 4 before the sound distorts as the amp is overdriven where as before [with the old cart fitted] distortion occurred at number 7 .I will try the 91 and see how it sounds
kirstyd is offline
Old 20th Jul 2021, 1:08 pm   #11
I've still got my membership card from back thenMoses & Joshua Dillard
ms660 is online now
