Old 6th Aug 2022, 10:09 pm   #1
clockman
Default Pilot Little Maestro T105
Re the dial Bulb can i have help with the replacement of the 10 volt 0.2 Amp MES dial bulb as this is not now available can i use a different one with a resistor shunt as it needs to be quite bright maybe use a led one advice please TAB
clockman is offline
Old 8th Aug 2022, 10:51 am   #2
Default Re: Pilot Little Maestro T105
A common 12V 2.2W automotive instrument bulb could work OK.
The bulb current is actually a dirty mix of 100mA ac plus the dc HT current of the whole set, around 40mA so it shouldn't overload the 2.2W bulb.
Otherwise you could bung a 56R 3W resistor in the line, hang a small silicon bridge across it and experiment with LEDs and series resistors!
Herald1360 is offline
Old 8th Aug 2022, 1:23 pm   #3
cathoderay57
Well you can get qty 10 x 10v 0.2A here https://www.ebay.co.uk/itm/352161969726 and maybe offer the surplus to other T105 owners on the Forum? Alternatively, if that's too much money, then I would think you'd get away with this 12v 0.2A job without sacrificing too much brightness https://www.ebay.co.uk/itm/152993641737. Jerry
cathoderay57 is offline
Old 8th Aug 2022, 1:37 pm   #4
12V 2.2W LES bulbs are easily and cheaply available from the local car spares shop, I would try one. If it is too bright then a resistor in parallel will dim things a bit.
Old 8th Aug 2022, 2:04 pm   #5
Sideband
Sideband's Avatar
I'd go for those! Just over £1 each sounds good to me and you can keep a spare and offer the rest on here if you want to. Might as well get the right lamp rather than faffing about trying to get the wrong type to work acceptably.
Sideband is offline
Old 8th Aug 2022, 3:02 pm   #6
David G4EBT
David G4EBT's Avatar
I'm sure that a 12V 0.2A would be fine, though admittedly the pack of ten 10V 0.2A from Germany are the real deal, and with free P&P are good value.
If I'm reading the circuit correctly (someone will soon tell me if I'm not!), although not immediately obvious, the pilot bulb is in the series heater chain - at least in series with one side of the mains. Depending on how the mains plug is wired the bulb might be series with line or neutral. If the bulb fails, the radio will be dead.
The total voltage dropped by the hearer chain is 124V. (V1 19v, V2 17V, V3 50V, V4 38V). The heater current is 0.1A. The bulb is rated at 0.2A so will be underrun, which is no bad thing as it will prolong its life. I doubt that the 2V difference of either a 10 or 12V bulb will be noticeable, bearing in mind that the radio will be on the 240V mains tapping, and the mains will probably be a few volts below that.
Nice little radios.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 8th Aug 2022, 3:17 pm   #7
According to the service sheet the DC load current is approx. 60mA so the current flowing through the lamp will be near 200mA.
Old 8th Aug 2022, 4:26 pm   #8
clockman
I have taken the advice of Sideband and ordered 10 from Germany i will keep 5 so any one can have the rest for £1 each + post i also have 5 recovered metal rectifiers for free Ex Ultra Twin. TAB
clockman is offline
Old 8th Aug 2022, 4:38 pm   #9
clockman
They are a nice radio to work on very well made the service sheet is very basic not a lot of detail shows op valve as UCL82 uses a UCL83 print hard to read but hope to get my one working well.TAB
clockman is offline
Old 9th Aug 2022, 9:12 am   #10
Sideband
Sideband's Avatar
Later versions did use a UCL83 as a cost reduction exercise. I have had both versions (now sold on). I've never seen the later circuit with UCL83 so be aware that the valve pin connections are different. I think the scale lamp is described as a 'fuse bulb' so probably better to keep the correct type if possible.
Sideband is offline
Old 9th Aug 2022, 9:17 am   #11
Sideband
Sideband's Avatar
...plus the HT current which will add another 50 or so mA to the current so the bulb is probably running at around 150mA give or take.....
Sideband is offline
Old 9th Aug 2022, 9:47 am   #12
Plus the rest (reservoir capacitor charging current)
