8th Apr 2020, 8:24 pm | #1 |
Ultrasonic cleaning
I saw a video on Youtube the other day in which someone restoring a vintage radio used an ultrasonic cleaning bath to de-grime various parts including a tuning gang.
Has anyone had experience in using one of these? They are obtainable quite cheaply. But I don't want to either buy something I will only use once or twice, or something that could damage fragile components. I dread to think of something that could reduce "monkey metal" parts to a heap of sludge! |
8th Apr 2020, 10:05 pm | #2 |
Re: Ultrasonic cleaning
This topic crops up from time to time.
Rather than go over old ground, this thread might be of interest: https://www.vintage-radio.net/forum/...asonic+cleaner The conundrum is that whilst they’re invaluable when needed, for many, the limited use doesn’t warrant the expenditure on a really effective bath. My own experience is that as with most things, you get what you pay for. The bath needs to oscillate at sufficiently high amplitude to be truly effective. I tried two cheap ones with disappointing results, which went back for a full refund before I bought an effective one. That said, others claim good results with cheap ones, but I doubt they would have a tank large enough for a two-gang tuning capacitor.
8th Apr 2020, 10:09 pm | #3 |
I think there was a lengthy thread within the last six months on this.
Those cleaners are wonderful if you get a good one, but much caution required if buying the budget ones. B
Saturn V had 6 million pounds of fuel. It would take thirty thousand strong men to lift it an inch. Last edited by Bazz4CQJ; 8th Apr 2020 at 10:38 pm. |
9th Apr 2020, 4:34 pm | #4 | |
I was lucky to get a small one at a charity shop, a real one that works well for small items. It also has a digital timer that can be set for several minutes or so. I used it to clean a ball bearing for a project. |
14th Apr 2020, 1:58 am | #5 |
14th Apr 2020, 3:50 am | #6 |
That's really interesting! I doubt if it competes with a professional grade ultrasonic cleaner for really critical processing (aerospace/defence), but for DIY, it very probably beats many of the "budget ultrasonic cleaners".
Also useful for when a part is too big for an ultrasonic bath. B
