20th Apr 2020, 6:49 pm | #1 |
ARC unit Identification
I wonder if any forum member can identify this unit please. It was shown on another site trying to see what it was used for. Mods if this is not permitted please delete with my apologies, thank you.
John |
20th Apr 2020, 7:55 pm | #2 |
Re: ARC unit Identification
Looks very much like some sort of control box, or possibly ground test set for a radio compass?- the frequency ranges are the sort that a radio compass is useful over, not to mention the controls labelled loop and the compass dial itself. The meter at top left is a vibrating reed frequency meter, maybe this confirms 400Hz (or whatever) from aircraft supply or ground converter for running PSU/motorised components of the system?
21st Apr 2020, 8:58 am | #3 |
Made by Aircraft Radio Corp of USA.
As per John's reply, it is an aircraft ADF Radio Compass Unit (using NDB or BC stations), or a ADF Test Set. The vibrating reed (centered on 100Hz) meter suggests the latter, as there is no need for this on an ADF/NDB receiver? I am not an historical expert, but I seem to remember ... Older Auto Loop Antennas sometimes used commutation (switching) of two loops at 100 Hz to generate a simulated "Needle points to selected bearing". This 100Hz commutation as the reason that we always kept hum on ground NDB carriers (and mod) to be as low as possible, and always less than 5%. Otherwise it had the potential to interfere in the aircraft ADF sense. . |
21st Apr 2020, 9:21 am | #4 |
The tuning scale, bandswitch and BFO switch says it contains a receiver. The frequency meter says it is a test box. The frequency ranges include the NDB band plus other stations that might prove useful for getting a fix.
I think it's a tester specifically for ADF antenna systems. David
21st Apr 2020, 6:08 pm | #5 | |
Possibly the small round window beneath the frequency meter is a carrier level indicator? Interesting observation about keeping hum out of NDB carriers. Last edited by turretslug; 21st Apr 2020 at 6:14 pm. |
22nd Apr 2020, 11:39 am | #6 |
Thank you all for your replies, I have passed this information on.
John |
22nd Apr 2020, 8:50 pm | #7 |
That is an ARC BTK-21 ADF test set system circa 1960. It is for bench testing units of the ARC Type 21 and 21A ADF equipment. It measures loop compensation, among other things, and when mated with a Type 21 receiver, loop and power supply will make a complete ADF installation. Runs off either 14 or 28 Volts. I guess no one here ever worked in an avionics shop 50 years ago?
23rd Apr 2020, 1:06 am | #8 |
Hmmm!
50 yrs ago, I was working on ANAV Ground eqpts, ILS, and RSR. On the other side of the airport. Thanks for ID'ing the equipment. Just shows the breadth of experience on this forum. There is something to be said for type plates on the front of equipment. http://www.bunkerofdoom.com/lit/ARC_1960_cat.pdf Last edited by Radio1950; 23rd Apr 2020 at 1:15 am. |
23rd Apr 2020, 7:06 am | #9 |
Approaching 50 years ago, I was working on the avions not the avionics Now it's the avionics turn.
These sorts of testers came and come in two families: 'Bench Testers' are comprehensive testers designed to test equipment to full manufacturer's or certification specs. 'Ramp Testers' are portable cut-down versions which get taken to the plane and used to do more limited checks of the equipment in situ. (The ramp is the name of the place the plane is parked for maintenance) Ramp testers assume that the equipment being tested either has already been fully bench tested and it's just the installation job which is being checked, or that if something incorrect is spotted on a ramp test, the offending unit will be quickly pulled out of the plane and sent to meet a bench tester. Some of these bench testers are staggeringly expensive. David
23rd Apr 2020, 8:09 am | #10 |
Coming from the aircraft manufacturer's side (I spent my career at BAC/BAe/BAE Systems Warton on aircraft such as Tornado and Typhoon), our term for such test units was always STTE, for Special to Type Test Equipment. This distinguished it from standard lab equipment such as oscilloscopes or test meters.
Andy |
