Old 28th Jun 2018, 8:09 pm   #1
matspar
matspar's Avatar
Default Ferguson 998T
Good evening Gentlemen,
Would anyone happen to have a scan of a Trader sheet for a 1953 Ferguson 998T by any chance? 12" table set.
Did this ever appear on a BVWS CD? My copy only has radios.
Best regards, Matt.
matspar is offline
Old 28th Jun 2018, 8:49 pm   #2
MonochromeMarc
MonochromeMarc's Avatar
Default Re: Ferguson 998T Trader Sheet
Hi Matt,
I've got a 998T, not a bad set either.
I have scans of the original Ferguson service data.
PM me your email address if you would like a copy sending.
Marc.
MonochromeMarc is offline
Old 28th Jun 2018, 8:52 pm   #3
matspar
matspar's Avatar
Many thanks Marc PM sent
matspar is offline
Old 28th Jun 2018, 8:53 pm   #4
Boater Sam
For very little money see
https://**********************/Schemat...son&model=998t
Sam.
Boater Sam is offline
Old 28th Jun 2018, 10:14 pm   #5
matspar
matspar's Avatar
Thanks Sam looks very interesting. I'll definitely have some of that. I've never stumbled upon this site before
matspar is offline
Old 29th Jun 2018, 9:10 am   #6
Heatercathodeshort
Heatercathodeshort's Avatar
One of the most reliable models ever produced. The last old style 12" model produced by Thorn. A simple circuit for the service area.
The last production run had provision for very simple Band 3 conversion.
Many of these ran for over 10 years without having the back removed. When I was around 16 I worked with a guy who had been an engineer during the early days of DER. He said that many were working well years past their life expectancy and despite suggestions that the customer should update their receiver, they were more than happy to keep it!
This example was found in a dry basement about 25 years ago and only required replacement of the Dubiliar wax caps and a LOPT dry out to put it back into service. I expect it was still working well when set aside. Took the pics this morning. Regards, John.
ID:	165332   Click image for larger version
Heatercathodeshort is offline
Old 1st Aug 2018, 9:48 pm   #7
matspar
matspar's Avatar
Hello John,
Only just stumbled on your message, not visited the forum for a little while. The 998T was the first 405 set I owned as a teenager back in the early 1990s. I couldn't get it to work so it sadly ended up being pulled apart and wrecked. Found another one all these years later to restore. It has low eht and the EY51 won't light. Fairly decent line whistle however, but no sparks from the top caps of the PL/PY81's. Tiny little spark available from the EY51 anode. This is new as well, and its heater winding is intact.
I'm satisfied that it is not the PL or PY (new ones fitted and even subbed for known good ones to prove a point, but no differences) All voltages are very near to circuit, nice stable HT nothing amiss and all the leaky dubiliers and a few high value resistors replaced.
So, looks like either incorrect line drive or a duff coffin lopt. I'm suspecting the lopt at this point. I have an identical good working one from a fringe version 991T but it lacks the osc feedback winding present on a 998T, so no good unless I'm brave enough to dismantle the pair and experiment with them! Any thoughts?!! the lopt has been sunbathing on a nice bright and red hot window sill over the last few weeks but no improvements...
Matt
ID:	166906   Click image for larger version
matspar is offline
Old 2nd Aug 2018, 8:22 am   #8
Heatercathodeshort
It does sound a bit like the LOPT. The line timebase is self oscillating and this adds a bit of complication when it comes to LOPT substitution.
The space available and the fitting of the coffin gives very little room for experimentation.
It might be possible to add the feedback winding to the limb of the transformer for the 991T but this is a more complicated unit for a 14" 70 degree tube and may not be suitable. John.
Old 2nd Aug 2018, 3:18 pm   #9
FERNSEH
FERNSEH's Avatar
Hi Matt,
If the line output transformer is proven to be faulty a possible solution is fit the spare transformer and make up a separate line oscillator.
Alternatively, the self oscillating line output stage of the later version of the Ferguson 983T could be considered. Oscillation is maintained by feedback components C23 and R28 which are supplied from a tapping on the LOPTx. See attached circuit diagram.
DFWB.
FERNSEH is offline
Old 8th Aug 2018, 11:06 am   #10
Restoration73
Restoration73's Avatar
The Trader index only lists 998T as (near) on sheet 1108, i.e. Ferguson 992T, 994T, 996T
and there is a 992T modifications sheet 1131.
Restoration73 is offline
Old 8th Aug 2018, 10:55 pm   #11
matspar
matspar's Avatar
Many thanks! I have the above trader sheet now, along with the full Ferguson service book. Neither show an exact circuit of the line timebase for the 998T although the factory book does show the component location and list of values. It does seem to be a hard one to pin down.
Thanks John and David, I have been contemplating both approaches. The 991T loptx would be a pure experiment due to the inherent differences.
I have since been offered a correct replacement by another friend and member so fingers crossed I won't have to go down this road!
It's a really nice clean and original set as well, apart from the muck on the tube face!!
matspar is offline
Old 19th Aug 2018, 5:40 pm   #12
matspar
matspar's Avatar
I have obtained a correct lopt and fitted it today. It worked briefly with a nice strong line whistle, the EY51 had a slight glow from the heater (although not as bright as it could be)
Still no screen illumination.
The overwind then became very warm and the pitch 'tyre' began to melt so I suspect this one has developed shorted turns. I'm now back where I started with a weak line whistle and no EY51 heater!!
I'm now thinking of removing the overwind and fitting a solid state tripler to try and get some eht which I've successfully done in the past.
However due to the line oscillator arrangement on the 998T, if I was to do this would the lack of an overwind upset the oscillator feedback winding on the transformer?
Matt
matspar is offline
Old 19th Aug 2018, 7:02 pm   #13
Heatercathodeshort
No I would not think so.
A doubler might be better than a tripler. A maximum of 9KV is required. You can probably construct one on a small square of Paxolin if a doubler proves difficult to obtain.
The Thorn 20" type would be fine or the small screen 1400's. J.
Old 20th Aug 2018, 10:03 pm   #14
matspar
matspar's Avatar
Thanks muchly John I will experiment with this when time allows!
matspar is offline
Old 21st Aug 2018, 9:22 am   #15
beery
beery's Avatar
Matt
Hi Matt,
It should be fine, the lack of EY51 heater loading may have more of an effect, but I'm sure it will still be ok. Shame about the overwind though (again!).
Andy
beery is offline
Old 25th Aug 2018, 12:22 am   #16
matspar
matspar's Avatar
Thanks Andy!
Just my luck again. If anything it's confirmed the original diagnosis. I'll cut the overwind off one of the scrap lopts then and have a little play around with some doublers and triplers, and see what happens! Worked a treat on my Pye VT2 which had an identical fault.
matspar is offline
