25th May 2020, 9:01 am | #1 |
Cossorscope 1076 80MHz model?
Hi!
In the back of my "Radio And Electronic Laboratory Handbook", first 1961 edition with a yellow dust jacket, in the advertisements at the back, there's an advertisement for an 80MHz "Cossorscope Model 1076"– https://books.google.co.uk/books?id=...201076&f=false Pages 561 and 562 of this:– https://archive.org/details/in.ernet.dli.2015.16346 Does anybody know anything about this and has any bookwork ever surfaced about this model? It looks to be clone of a Tek 547a or similar, it's advertised as having the same "beam direction indicator" neons as the Tek models have! Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 25th May 2020 at 9:14 am. |
25th May 2020, 9:07 am | #2 |
Re: Cossorscope 1076 80MHz model?
Curious. Looks like a re-imagining of the Tek 536 X-Y scope but with higher bandwidth. I like especially the "light weight, only 104lb" claim!
Chris
25th May 2020, 10:46 am | #3 |
25th May 2020, 10:56 am | #4 |
Hi Chris
Perhaps you could find out about my Cossor 1059 Pictures in #6 of threat below https://www.vintage-radio.net/forum/...ighlight=Scope. It predates the 1076 but also has a number of features including weight! Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 25th May 2020 at 10:58 am. Reason: errors! |
29th May 2020, 8:00 pm | #5 |
I had a look in my Cossor test equipment folder couldn't find the 1076 scope other than advertising material but did find the handbook for the 1083 Plug in.
I may still more, I have hundreds of unsorted documents the 1083 is described as a Calibrated delay unit for the 1076 If the document follows other Cossor document numbering its dated 1961 Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 29th May 2020 at 8:02 pm. Reason: spacing |
