Old 26th May 2009, 4:49 pm   #41
Steve_P
Steve_P's Avatar
Default Re: Murphy A242 VHF IF Alignment
At the time, Murphy were not allowed to use the VHF valves that Mullard had, as they had an agreement with Mazda. Also, in those days, VHF was for home only use and an external antenna was needed.
Align the whole of the VHF chain and put new valves in the VHF section. Check C1 and C2. Check the HT voltages to the valves and the cathode voltages.
Cheers,
Steve P.
Steve_P is offline
Old 26th May 2009, 7:10 pm   #42
JimMac53
JimMac53's Avatar
Thanks for the advice Steve. Interesting note about the valves Murphy was allowed to use. Concerning alignment, I pretty much plan to do that. I already know the voltages are where they should be (both anode and cathode). I have some other tubes I can sub-in. I also just acquired a Murphy A252, which is working and even though it's a later model (and different valve set), it does give me something to compare it to. Which makes me wonder: "How much variation in performance was there from set to set as it came off the factory floor? (this could be its own thread)" It would be nice to know how much gain each stage had, bandwidths, etc.
Jim Mac
JimMac53 is offline
