28th May 2009, 7:08 pm | #1 |
Grundig Party Boy 500 Poor FM.
Hi, i have just been given this radio from a forum member. It works perfect on AM but very poor reception on FM. I have cleaned the wavechange switches, but no better.
Malc Scott |
28th May 2009, 7:53 pm | #2 |
Re: Grundig Party Boy 500 Poor FM.
Hi Malc, This looks like a nice little radio, hope you can sort the FM problem I suppose this will be one of those sit down for a couple of hours with the door shut and a cup of coffee jobs Good luck, |
28th May 2009, 8:47 pm | #3 |
The service sheet is up top there. Check that the aerial is connected There are 2 coils and a cap that connect the aerial to the set. Check these.
Cheers, Steve P.
28th May 2009, 9:28 pm | #4 |
Hello,
I have one of these. Works great on AM/FM (touch wood!) Michael |
29th May 2009, 7:47 am | #5 |
FM IF alignment? Any sign of disturbed cores in the 10.7Mhz path?
Dave G1AGK. My perception is my reality! |
29th May 2009, 10:10 am | #6 | |
Administrator
I can't help with any definitive suggestions for the fault though. Check the aerial is connected OK (it uses a metal bracket that is soldered to the PCB), check for signs of the alignment being disturbed, and check for cracks in the circuit board in particular near the mountings and aerial. Then cast a suspicious eye over any electrolytics that are only used for FM. |
29th May 2009, 7:54 pm | #7 |
Hi, many thanks for the replies. I will download the circuit let you know of any repair updates. Cheers, Malc.
Malc Scott |
