8th Nov 2010, 8:00 am | #21 |
Re: Bodgery...in the interests of getting our sets going!
Rob's bodge reminds me of my old Ultra Transistor Six where to get it to work I had to apply pressure on the back of the wavechange switch. A few tie wraps going onto some metal work sorted that and after a couple of years the pressure applied had moved the wavechange switch so it worked perfectly
8th Nov 2010, 10:16 am | #22 | |
Cheers Billy |
8th Nov 2010, 11:57 am | #23 |
Just to clarify, it wasn't my bodge, I just found it. The pull in coil had gone o/c but the holding coil was ok. The piece of wood limited the travel of the solenoid so that the holding coil could just pull the contactor in.
Rob.
We have done so much, for so long, with so little, we are now qualified to do anything with nothing. |
8th Nov 2010, 12:14 pm | #24 | |
Never been a problem with 2000 amp fuses. In 2000 amp circuits. Always advisable to have leads with various connectors on one end and croc clips on the other. That way you can do such awkward connections as DIN to XLR and BNC to BS4343. The lead with a 13A plug on each end has its uses too, when you need to bridge power into an otherwise dead circuit. The EHT bodge on my 702 TV is interesting. I haven't yet fully dismantled it to fit the nice rewound transformer but there's a couple of transformers, a tripler(?) probably just being used as a single rectifier along with the original smoothing caps. Works perfectly, spot on 5kV, so no huge incentive to sort it out quickly. |
11th Nov 2010, 3:24 pm | #25 | |
Al
I won't tell you how I discovered that. |
15th Nov 2010, 2:44 am | #26 |
Re Sideband's orig. post,
I recently had to replace both IF transformers in a Columbus -NZ- radio,and although they came from a set with 455 Khz IF they were nowhere near this when put in the Columbus. There were no caps in the cans, so i tried 100pf and this moved resonance down to below 400 Khz. Replaced with 50pf and was now able to peak at 455 Khz. I'm wondering what influence circuit design has on IF transformer performance. Last edited by Station X; 15th Nov 2010 at 12:11 pm. Reason: if changed to IF. hz to Khz. |
15th Nov 2010, 9:33 am | #27 |
I hope that is supposed to be 455Khz.... SB
16th Nov 2010, 6:08 am | #28 | |
Peter |
28th Apr 2019, 11:39 pm | #29 |
The oddest forum related bodges you've encountered
Recently I was reading the home site of a collector who had the odd knack of picking up items that previous owners have performed some unorthodox repairs / upgrades.
These often seemed to be workarounds to avoid carrying a proper fault find & replace a faulty component. I'm not sure if the site owner is a member here, but most of his collection was 1940s-50s radios & televisions. When I was at Golbourne in November 2018 someone was talking about how he had to deal with a turntable that had been regreased with lard! I'm sure there have been threads like this before, but I'm sure there are still some interesting stories to tell.
29th Apr 2019, 10:07 am | #30 |
I once got a Sanyo colour television working again temporarily by replacing a failed stanbye transformer with one "borrowed" from a scrap Roger Black exercise / running machine
If smoking is so bad for you, how come it cures kippers? |
29th Apr 2019, 10:16 am | #31 |
I mended my parents' 1970s Indesit chest freezer using a motor from a Garrard 2025 and a model aeroplane propeller. It worked for many years.
29th Apr 2019, 11:01 am | #32 |
A safe bodge to a wrongly wired domestic lighting circuit.
Downstairs hall and upstairs landing lights both controlled by the same pair of two way switches. Unfortunately the two lamps were wired in series, and this could not be corrected without installing an extra cable, a non trivial job as buried in the plaster. The lights worked but very dimly despite use of 150 watt lamps. A quote for several hundred pounds had been received to electrically rectify and then re-decorate. I simply fitted 120 volt lamps ! and supplied some spares. |
29th Apr 2019, 11:05 am | #33 |
I once repaired an Intercity 125 train set by replacing the burnt out/original/obsolete clover-leaf motor, with a motor from a scrap CD-ROM tray drive.
Not only was the train much faster, it was an awful lot quieter too. The gentle sound of the train going over the track joins being the overriding sound, as it whispered along 15 years later, still working. Mark
Slowly turning the 'to-do', into 'ta-dah' |
29th Apr 2019, 5:45 pm | #34 |
Primary School play in the 1960s. 9 year old me was 'Assistant Lighting Director' in charge of home made lighting consisting of spotlights in plywood and cardboard enclosures covered in aluminium foil.
Unfortunately the plug fuse blew whenever the contraption was switched on so Teacher in charge paralleled two 13A outlets using flex, choc blocks and insulating tape with instructions to myself and 2nd Assistant Lighting Director to ensure we switched the two sockets on and off simultaneously. I'm not sure whether that's better or worse than solid brass fuses but the show went on. He'd probably have been sacked if anybody had found out, even in those days. |
29th Apr 2019, 6:40 pm | #35 |
BASF 5 1/4" disc drive, head failing to pull in. Hold in worked but no one shot to get it moving.
Found odd dil14 chip had 4 one shots in it, one failed, totally no longer available. Take a 74 series one shot, patch one section onto the pins of the original, upside down. Worked till I gave it away. |
29th Apr 2019, 6:57 pm | #36 |
Bodgery by Joe Public divides the population in two.
Townies fixed everything with Sellotape, Ruralites used baler twine Dad, having a garage business, used welding rod. David
29th Apr 2019, 7:04 pm | #37 |
In this application, isn't an old wire coathanger just as applicable? Rehangs exhausts and fixes radio aerials too! Galvanised ones are better for the latter....
29th Apr 2019, 7:47 pm | #38 |
Only 2 things are needed for most bodge repairs, duct tape and a hammer. If something that should move doesn't - use the hammer. If something that shouldn't move does - use the duct tape.
29th Apr 2019, 8:56 pm | #39 |
Worst bodge I can admit to as yet, regards getting a set working, is probably taping a broken PP9 connector's terminals on the top of a PP3 battery... There's time yet though and I have some valve data books plus a '30s set missing a PX4 here, so will likely be some more bodgery to report in future.
29th Apr 2019, 8:59 pm | #40 |
There's also the similar 'glue it or grind it' approach... not that I necessarily approve!
...where on earth did that spring/screw go?? |
