30th Apr 2019, 7:56 pm | #1 |
Mains transformer failure without obvious signs
Recently one of my multivolt wallwarts died. Initially I had suspected that the LM317T regulator inside might have failed, but replacing it made no difference. I was then surprised to discover that it was the primary winding of the mains transformer that has become open. I didn't feel it getting hot or see any smoke coming out, so was wondering how this could have happened ? Has anybody else experienced the same ?
30th Apr 2019, 8:09 pm | #2 |
Re: Mains transformer failure without obvious signs
In some of these there is a small thermal fuse in the primary winding that just goes open circuit for no apparent reason. I have had it happen a few times.
30th Apr 2019, 8:15 pm | #3 |
In the 1980s Solavox (ITT chassis) TVs sold by Comet used a small mains transformer to power the remote control circuitry and customers usually left their sets plugged in permanently. A common fault was the transformer primary going open circuit resulting in a "dead" set. I don't know what caused this though.
Regards Martin |
30th Apr 2019, 8:59 pm | #4 |
When the unreplaceable thermal fuse in my 3 month old DAB tuner failed, I requested
and received a new transformer. Failure was caused by disc ceramic across the bridge going short circuit (nasty 50V ceramic, should have been 100V). The manufacturer had of course fitted an external fuse in the primary winding, but there is little point in a T2A fuse when the primary current was 43mA rms. I fitted a T250mA fuse and have had another 15 years of service. |
30th Apr 2019, 10:30 pm | #5 |
No Longer a Member
If you look at the side of the transformer bobbin, sometimes its possible to see the thermal fuse wires. I have seen one where the fuse has blown, and been shorted out for a repair, but an additional fuse is added in series with the primary, for a small wall wart 100mA fuse was added, as I recall.
1st May 2019, 12:38 am | #6 |
I attempted to locate the fuse but could not find it even after stripping the primary terminal coverings down to this level. There is still an open circuit which makes me think that the problem is too deep-seated for repair.
Secondary windings shown for interest. |
1st May 2019, 1:57 am | #7 |
I'm guessing cheap chinese wall wart -> no thermal fuse in these things, any safety protection relys on luck.
1st May 2019, 3:43 am | #8 |
Sometimes the measured capacitance of each terminal of the open-circuit winding can help 'deduce' where the open-circuit is located.
As an example, if a layer-wound primary winding was sandwiched between the core and a secondary winding, then capacitance of a primary terminal to core, and to secondary, could be noticeably different depending on the primary terminal tested. A wire break at or very close to a terminal would likely give a very low capacitance from that terminal to anything else. That test confirmed where the break was in one vintage transformer for me, and allowed an easy fix. Of course if the break is embedded in the winding (eg. a hot-spot type of failure), then it won't be a practical fix option (except as a rewind), and capacitance readings could be very indecisive. |
1st May 2019, 4:13 am | #9 |
No Longer a Member
1st May 2019, 5:46 am | #10 |
Argus!! is a $3 transfomer that is MOST likely dipped worth repair?
Tim!! is a $3 transfomer even worth testing? It will be "so close" to what is available off shelf for about $10 from ( In Australia) from various suppliers, it simply isnt worth the effort. In fact a look at the local Saint Vinnies or Salvation Army shop will most likely yield 10 of each wall wart required for 50 cents or perhaps a $1 each. Sorry guys Joe |
1st May 2019, 9:36 am | #11 | |
To answer your question, though, you're not the only one for this to happen to. |
1st May 2019, 3:11 pm | #12 | |
2nd May 2019, 5:31 pm | #13 |
Sometimes the thermal fuse is right up against the copper windings. It's there to break the circuit if the transformer gets too hot, not (by design at least) to open on overcurrent. I too have seen this failure on transformers, and recently on the motor in my bathroom extractor fan.
2nd May 2019, 6:20 pm | #14 |
I've autopsied a couple of these where the failure has been in the few mm of the very fine primary winding emerging from the transformer and soldered to one of the tags. Could this be caused by some sort of metal-migration effect (in the same way as solder would erode copper soldering-iron bits)?
Disassembled and stripped/rewound, these little wall-wart transformers can find a second-life as push-pull driver- and output-transformers for 'classic' couple-of-Watt audio-amps with a pair of OC81/AC128/AC153 or something like two BFY51 if you want to go silicon. Biggest problem is getting them to come apart if they've been resin-dipped. |
2nd May 2019, 7:50 pm | #15 |
2nd May 2019, 8:44 pm | #16 | |
Annoying when it happens though. |
2nd May 2019, 10:29 pm | #17 |
In my experience, small mains transformers are often wound with a rather mean turns per volt on the primary - and using very fine wire. So even if a primary fuse is fitted (often not), chances are that with an overload, even a relatively small one, the primary will immediately go O/C.
Al. |
2nd May 2019, 10:56 pm | #18 | |
No Longer a Member
http://worldphaco.com/uploads/VOTRAX...TS_HERO_JR.pdf |
3rd May 2019, 1:17 am | #19 |
This is the regulated voltage selector circuit of my old wallwart. Here are some pictures with the heatsink removed. The LM317T was screwed on to it and thermal paste had been used. The switch contacts form part of the double sided PCB itself and the voltages were selected by switching in/ out various resistor combinations. The six holes on the PCB are where the six secondary wire tappings from the burnt stepdown transformer were connected.
3rd May 2019, 4:16 am | #20 |
I see your point Terry, but it's not often a supply such as yours is required. In that case I would have done something similar, although truth be told I wouldnt have bothered or tried to repair it.
I would not have charged the customer. Joe |
