Old 26th May 2008, 5:24 pm   #1
kosunen
Default AVO CT160 buzzing with certain valves
Hello, I'm new here, looks like a good forum.
I am in the process of testing lots of valves on an AVO ct160 which seems to be working well. The only problem so far has been a buzzing noise when testing valves with "CL" in the name eg. ECL80, PCL83 etc. This isn't the warning buzz, it sounds different and the warning light doesn't come on when it happens. It seems to happen on just about every valve with "CL" in the name when I rotate the knob to "test". Does anyone know what causes this and is it anything to worry about?
Thanks.
kosunen is offline
Old 26th May 2008, 5:46 pm   #2
Dave Moll
Dave Moll's Avatar
Default Re: AVO CT160 buzzing with certain valves
xCLnn signifies a valve containing a triode, and a power tetrode or pentode, if that helps at all.
Dave Moll is offline
Old 26th May 2008, 6:12 pm   #3
Sean Williams
Sean Williams's Avatar
It could be that the internal connections to the valves are connected to "spare pins" - Ct160 does not like this!
Sean Williams is offline
Old 29th May 2008, 8:09 pm   #4
Alf Fisher
I think the buzzing sound can come from the mains transformer when it is called upon to supply more current than about 30mA. I don't think it is anything to worry about. Sometimes when testing high current rectifiers, I get the impression that the overload trip is about to operate so that could also be a possible cause of the buzzing as the valve types mentioned contain power output pentodes.
Alf
Alf Fisher is offline
Old 29th May 2008, 8:36 pm   #5
wave solder
wave solder's Avatar
The buzzing sound can also be caused by an incorrectly adjusted cutout .........
wave solder is online now
Old 7th Jun 2008, 1:35 pm   #6
kosunen
Thanks for the advice everyone. I will have a look inside the machine at some point. I think it needs some calibration too but thats a whole other topic!
kosunen is offline
