Old 14th Nov 2008, 4:26 pm   #1
Keith_B
Keith_B's Avatar
Default Bush TR82B
I have been after an "82 B" for some time and everyone always says how reliable and easy to work on these sets are.
This one was acquired in non-working condition. When I examined it, it looked clean enough but the tuning dial was loose. When I turned the dial the pointer stayed put! Removed the dial (string method) and removed chassis.
The rubber bushes had crumbled away and the vanes were seized up. I had some 20mm bushes (used in the electrical trade) and cut them more or less in half. I then curled them up and forced them into the original holes. I then inserted the brass sleeves.
The tuning capacitor was then looked at to see why it had seized. As no vanes were bent I went to the rear and with a spanner and screw driver loosed the end bearing. As soon as I loosened it the capacitor could be moved. I removed the adjusting screw completely and cleaned the five ball bearings with WD40. I then lightly greased the ball bearing and reassembled.
One of the ball bearings was larger than the others and goes in the middle and acts as a pivot. I inserted the bearing with a tooth pick. When I adjusted the end bearing I tightened it so that the vanes looked equal distance to each other when they were meshed.
The radio then worked OK.
ID:	21293   Click image for larger version
Name:	Bush tr82 repair(0).JPG
ID:	21294   Click image for larger version
Name:	Bush tr82 repair (2).JPG
ID:	21295   Click image for larger version
Name:	b tuning c.jpg
Keith_B is offline
Old 14th Nov 2008, 4:49 pm   #2
howard
howard's Avatar
Default Re: Bush TR82B
Well done Keith,
These and the early TR82Cs don't give a lot of trouble cos they don't have AF117 transistors fitted. I've never heard of a tuning capacitor seizing up as bad as this one was but it was easy enough to fix. The rotten grommets is a common problem, one can get replacements which fit without surgery from Halfords for 99p.
Howard
howard is offline
