14th Jul 2017, 12:17 pm | #41 |
Re: Valve amplifier issues... Help Please
I have one of these players, havn't actually seen it for a while, in the roundtuit pile, with the other chanel extra valve amp fitted. The controls on the front are twin gang for Stereo, I assume you got that whether you you specified mono or stereo when bought new. The requirements for a power supply for two as opposed to just one amplifier are hugely disparate, if you bought a mono player and later upgraded to Stereo did you get a bigger mains transformer fitted too? If not you would think HT voltage would be considerably reduced
14th Jul 2017, 12:57 pm | #42 |
Too much unknown variables in this equation, but simple experiment would help :
1. Measure HT voltage and max current that this circuit draws. 2. Check the max current available from the rectifier valve. If it can handle twice as much : 3. Add voltage dropper in parallel, to get the current twice as much as without the dropper. 4. Measure HT voltage again and sound quality. 5. Check the transformer temperature. Power off if too hot. J |
14th Jul 2017, 2:32 pm | #43 |
14th Jul 2017, 2:36 pm | #44 |
From this post: http://www.vintage-radio.net/forum/s...40&postcount=1
It would appear that there were at least two versions of the GR4, the SA and ST. Presumably they both had ganged controls and adequate power capacity, the SA just lacking the sub chassis, as with convertible TVs. I'm inclined to agree with Kalee20 that with matching speakers it would produce reasonable stereo reproduction for it's market position. Also with the majority that this was not a Dynatron modification, although it is quite workmanlike, by no means a rough bodge. Does anyone know of a straight GR4 without a suffix? |
14th Jul 2017, 2:45 pm | #45 | |
it looks like this until was originally bought as a mono unit but was upgraded in 1974 to stereo, it was wired for a stereo cartridge, the second power amplifier has its own power transformer but was created using transistors rather than valves.. |
14th Jul 2017, 2:54 pm | #46 |
Thank you for this valuable advice...but i now have it working not just in Mono but in Stereo too and have put it all back into the case it came in so i wont be doing any more testing on it.
14th Jul 2017, 3:01 pm | #47 |
15th Jul 2017, 2:38 pm | #48 | |
I think you may be overlooking something. Stereo isn't just simply two channels of sound, things such as phase differences are pretty important. If the two channels are not as identical as they can be, you will get all sorts of equalisation and phase-differences, which would mean that the stereo image could be hopelessly compromised. In my younger days, I tried listening to stereo vinyl using an Armstrong receiver on one channel and an RSC 20-watt ultra-linear push-pull amplifier on the other. The loudspeakers were totally different, too. To my uneducated rag ears, it sounded ok at the time, but then I didn't really know what stereo was supposed to sound like. So yes, it would have "worked" and "sounded good" to someone like my youthful self, but that still doesn't make it proper stereo "like it oughta be". Colin. |
15th Jul 2017, 6:34 pm | #49 |
Please check your attributions, I never said that all amplifiers sound the same. In fact I implied that one channel on a valve amplifier and the other on a transistor amplfiier might well not sound that good. As far as I know all 'reasonable' stereo systems had identical amplifiers for the 2 channels.
That said, Philips sold a little transistorised preamplifier for some of their 4 track tape recorders. One use was to allow the playback of stereo tapes. You played track 1 (left channel) through the tape recorder and track 3 (right channel) through this preamplfiier and your radio (feeding the signal into the pickup sockets on the latter). No way are those 2 amplifiers going to be the same. But I guess it was better than nothing. |
15th Jul 2017, 7:41 pm | #50 |
Attribute corrected, yours was a quote within the post.
16th Jul 2017, 12:24 am | #51 |
An ideal valve amplifier and an ideal transistor amplifier would sound the same. However, we are talking about real amplifiers which deviate from ideal behaviour -- and different technologies can be expected to deviate from the ideal in different ways. In practice, valve amplifiers tend to produce distortion mainly in the form of low harmonics (nothing beyond the 5th) whereas transistor amplifiers tend to produce distortion mainly as odd harmonics at low levels, but spead all the way up the audible spectrum.
A transistor amplifier with a lower THD figure than the valve amplifier would produce less of the objectionable high harmonics, and probably would sound similar enough in practice. My personal experiments with heterogeneous stereo suggested that some mis-matching was quite acceptable for most sources, with a few exceptions.
16th Jul 2017, 10:56 am | #52 |
Interesting thread.
Yes, this is a stereo-adaptable machine from the early 1960s that someone's adapted to stereo at a much later date using a neat, home-made, solid-state, amp instead of the Dynatron LF18/ST which it was intended to accept. Your four choices would seem to be to look for an original LF18/ST (good luck with that!), make up your own LF18/ST copy, keep it as-is and tidy up the dangling rectifier etc., or remove the added stuff and get it back to its original mono-but-adaptable-for-stereo state. Personally, I would leave the addition in place. It would be easy enough to remove later should the urge take you. N. |
16th Jul 2017, 10:59 am | #53 |
Manufacturer's data available here: http://www.service-data.com/product....03/1802/m11303
16th Jul 2017, 11:03 am | #54 |
And this is what the original bolt-on module would have consisted of, i.e. two valves, and output transformer and a handful of passive components:
16th Jul 2017, 2:17 pm | #55 | |
Colin. |
