6th Apr 2019, 5:18 pm | #1 |
What are these transformers?
Can anyone advise what these maybe or from? Thanks
6th Apr 2019, 5:20 pm | #2 |
Re: What are these transformers?
Microphone transformers?
Andy |
6th Apr 2019, 5:37 pm | #3 |
That’s what I thought Andy, could they have come from or be used in a mixer deck?
Cheers John |
6th Apr 2019, 5:51 pm | #4 |
If you can find any legible details on them (manufacturer's name and/or part number) then it's worth checking whether they can be re-purposed as step-up transformers for moving coil phono cartridges. If so then they might be worth money.
Cheers, GJ
http://www.ampregen.com |
6th Apr 2019, 7:16 pm | #5 |
Also very useful to reduce hum on sensitive input circuits, much beloved by the BBC.
Ed |
6th Apr 2019, 8:13 pm | #6 |
Could also be line isolating/matching transformers for things like 600 Ohm phone lines etc.
The first step is to use an audio generator and scope to measure the ratio(s) and then measure the bandwidth. David
6th Apr 2019, 11:29 pm | #7 |
DONT test them with an ohm meter!!!
IF they have mu-metal cores ( and I suspect they do) you will permanently magnetise them making them worthless and useless as they will saturate more easliy in one direction than the other. If you want to test them use a sine wave generator set to a very low output to start with and observe the outputs with an oscilloscope Joe |
7th Apr 2019, 1:30 am | #8 |
Certainly audio matching or isolating transformers, and it looks like you have at least two different types. Can you make the markings more legible, on those that have them?
If you can measure the ratio and inductance of the windings it will give an idea of their use, and working impedances. |
7th Apr 2019, 6:58 am | #9 |
They look like they could be one of many varieties manufactured by Sowter
http://www.sowter.co.uk/pro-audio-transformers.php Craig |
7th Apr 2019, 9:18 am | #10 |
I've seen similar transformers used for impedance-matching dynamic microphones, in an old valve PA amplifier. I was surprised to see replacements were still available -- but not as surprised as when I saw how much for! You might have a veritable little treasure trove on your hands there.
With the current interest in analogue recording studio equipment, somebody might well want them off your hands and in a mixing desk they're restoring .....
7th Apr 2019, 9:41 am | #11 |
Hya..Thanks for the comments. I have a signal generator and scope so will have a look later. The comment re ohm meter, that is something i hadn't thought of.
7th Apr 2019, 9:58 am | #12 |
I wouldn't have thought a modern digital meter would put out enough current to magnetise a transformer core permanently, but mu-metal is funny stuff.
Would that mean it would be a bad idea to try to use an electret microphone into one of these transformers? Since the DC blocking capacitor on the output would have to charge through the transformer primary winding .....
7th Apr 2019, 10:52 am | #13 |
Its normally accepted that one DOES NOT use DC currents into a transformer with a Mu-Metal core!!
I will most likely be shot down, BUT please check transformer basics. Electret condenser microphones ?? WHY would anyone want one in the first instance?? Bass boomy, treble screetchy, PERFECT for digital!!. A half decent dynamic is far more desirable, and doesnt require ( 48 volts, no less) biasing voltages, nor does it kill superb little microphone coupling transformers of yesteryear. Just my two bobs worth Joe |
7th Apr 2019, 12:21 pm | #14 |
Transformer cores can be de-magnetised. Hit them with a big AC signal and then smoothly and slowly reduce it to zero. There is no need to dump the transformer or to dismantle it and anneal the lams.
If you use an audio sig gen to test one, don't just break the connection or switch off abruptly, diminish the signal gently to zero. Abrupt starts and stops of AC actually contain DC transient components. Condenser microphones are very good indeed. There are some superb condenser mikes and recordings made with them. Some even include valves, if that is of any importance. And plenty of polarising voltage is helpful. Electrets are less high-faluting but are permanently polarised, and the only power needed is for a high impedance buffer after the capacitor. They can live with lower phantom voltages. With care, condenser and electret mikes, transformer cores other than mumetal, transistor and digital circuitry can all be made to work very well indeed. Don't judge the whole just because there have been some grotty examples. There are some people around who can design things properly. David
7th Apr 2019, 6:05 pm | #15 |
I think they may also have been used as baluns, to match a balanced mic circuit to the unbalanced amp input.
Alan. |
7th Apr 2019, 6:13 pm | #16 |
Kevin |
7th Apr 2019, 10:01 pm | #17 | |
8th Apr 2019, 3:27 am | #18 |
The examples shown in post #1 only show four wires. I don't think you can use them for balanced inputs. ( I may be wrong). To me they look like input transformers that feed directly into a grid, base or gate connection. With or without decoupling caoacitors.
Joe |
8th Apr 2019, 10:51 am | #19 |
Assuming that it is a single primary/single secondary, yes they would work perfectly well with either a balanced or unbalanced input, the benefit in either case being earth-loop removal and improved common-mode rejection. Perhaps Joe, you are thinking of the centre tapped primary variety? Not often seen these days.
8th Apr 2019, 7:59 pm | #20 |
Sometimes referred to, back in the day when most had centre taps, as "floating" rather than "balanced".
