Old 19th Apr 2019, 7:35 am   #1
Argus25
No Longer a Member
Default Vintage amber VDU project
Recently I built two vintage NOS Zenith amber CRT VDU's into special order Takachi enclosures. One thing was a successful CRT gasket/mask that was machined out of 10mm thick black acrylic. Using thicker acrylic this could also be a method to recreate masks for vintage CRT's too.
The article/story is here:
http://worldphaco.com/uploads/THE_AM...DU_PROJECT.pdf
ID:	181499   Click image for larger version
ID:	181500   Click image for larger version
Argus25 is offline
Old 19th Apr 2019, 8:24 am   #2
Kentode
Kentode's Avatar
Default Re: Vintage amber VDU project
That's a very professional looking job, congratulations!
How did you arrive at the 700 mm radius of curvature of the crt?
Regards, Ken.
BVWS member
Kentode is offline
Old 19th Apr 2019, 8:40 am   #3
peter_scott
peter_scott's Avatar
As Ken has said, a truly professional job! Beautifully executed.
Peter
peter_scott is offline
Old 19th Apr 2019, 12:14 pm   #4
Argus25
No Longer a Member
I used a long string with a pen and drew curves on thin card, then cut them out and held them to the crt faceplate, in the end, through iteration, I found the radius of the faceplate.
Argus25 is offline
Old 19th Apr 2019, 1:35 pm   #5
Karen O
That is REALLY nice!
Mounting 5.5" CRTs has been a real bugbear. Sometimes I use the metalwork that comes with the TV. Other times I form a large hose clip into a kind of rim band. Your solution is better by far.
I like the SOL 20 too: perhaps the only desktop computer with an S100 bus card cage...?
Karen O is offline
Old 19th Apr 2019, 2:00 pm   #6
Argus25
No Longer a Member
One oddity about the Sol-20 is that the S-100 cards were mounted horizontally, unlike many other S-100 computers of the era where they were mounted vertically. They wanted to keep the whole case low profile and oddly that was because they had fixed height wooden sides because the company sourced the wood from a gun stock supplier and it had a limited height.
It is not ideal for cooling as the heat builds up between the S-100 boards. On my Sol-20 I added an extra fan to combat this. In my computer I run three 16k ram cards so I can run 48k CP/M and the heat between the cards is an issue. Also these cards have issues with their digital delay lines.
Here is an article about the cards, if you go to page 24 you will see the cooling fan I added:
http://worldphaco.com/uploads/PROCES...A_RAM_CARD.pdf
Argus25 is offline
Old 21st Apr 2019, 2:23 am   #7
Argus25
No Longer a Member
I just made a very short video of my Walking Man on the Amber monitor. This program was written in 8080 assembly language and uses plots of the $ symbol, since the Sol has no graphics screens, just text:
https://youtu.be/D8PEJsoEWUc
Argus25 is offline
Old 21st Apr 2019, 8:28 am   #8
Kentode
Kentode's Avatar
That does look good. I'm sure I've seen something similar on a European pedestrian crossing, possibly in Spain.
Regards, Ken.
BVWS member
Kentode is offline
