29th Nov 2018, 2:25 pm | #1 |
Bush DAC90A blocking capacitor location?
Got a crackly volume switch issue and the volume is loud I have been told to check the blocking capacitor, could someone point me into where this is please?
I have changed all the caps and resistors and a new audio transformer and have brought a dead set back to life just need to sort out this issue and I am done. Thanks Mike |
29th Nov 2018, 2:44 pm | #2 |
Re: Bush DAC90A blocking capacitor location?
A noisy volume control can be caused by excessive DC on the volume control, caused by a leaky coupling capacitor. But not in the DAC90a, where the design does inherently put DC on the control, albeit just a few volts, and nothing to do with a bad capacitor.
It's a new control you'll need. |
29th Nov 2018, 2:54 pm | #3 |
Or take the control apart and carefully clean the track and metal centre contact. Dont rub the carbon track hard or you may wipe away the carbon.
Then put a thin smear of grease on the track and the centre metal contact where the centre wiper makes contact. Mike |
29th Nov 2018, 5:08 pm | #4 |
Found a replacement from Bowood electronics so will give that a go
29th Nov 2018, 6:37 pm | #5 |
Changing all the capacitors and resistors seems unnecessarily heroic. Perhaps you meant a limited number of components recommended for replacement.
Any such list should have included the output grid coupling capacitor 0.01uf circled below.
-- Graham. G3ZVT |
29th Nov 2018, 7:14 pm | #6 |
Generally a waste of time changing all the resistors. Even if the originals are slightly off tolerance, changing them will make little or no difference. Valve radios are very forgiving (with a few exceptions) with resistor values.
