3rd Dec 2018, 2:24 pm | #1 |
Gecophone BC1001 what to use for the cats whisker
I bought myself an early Xmas present, a Gecophone BC1001 crystal set as I have always wanted one as they represent the earliest period of radio.
It is complete with a couple of crystal holders with crystals but the whisker is broken short. Reading around I see phospher bronze wire mentioned but is this the correct material as I assume the material has a significant impact on performance? Anyone know where I can get some from? If someone else has a BC1001 is it correct that the wire is simply secured by a screw? |
3rd Dec 2018, 2:49 pm | #2 |
Re: Gecophone BC1001 what to use for the cats whisker
I suspect the only useful property that phosphor-bronze has is its springyness. I think I used the hair-spring from an old watch when I was a child.
-- Graham. G3ZVT |
3rd Dec 2018, 3:20 pm | #3 |
When making "proper" crystal sets in my youth I used any old bit of thin wire, you don't need much spring as the contact is quite gentle.
3rd Dec 2018, 3:47 pm | #4 |
There's usually a bit of 'whisker' in the tin when you buy a new crystal.
3rd Dec 2018, 6:43 pm | #5 |
In the past when trying to find the rectifying 'sweet spot' on the iron-pyrites in coal, I used a pair of the bristles from one of the little wooden-handled suede cleaning brushes.
3rd Dec 2018, 7:40 pm | #6 |
When I had my first crystal set in the late 40s I simply had loads of fun experimenting with all sorts of bits of wire, any thing I could get my hands on, and then was amazed when I heard something in the headphone, just play around and have fun.
Cheers John |
3rd Dec 2018, 8:15 pm | #7 |
Yes the "whisker" wire is clamped under the head of a tiny screw.
Regards, Richard, BVWS member |
3rd Dec 2018, 9:23 pm | #8 |
Thanks Richard, just checking nothing was missing but it seems it is all there then.
3rd Dec 2018, 9:40 pm | #9 |
Either that's correct, or we've both got the same bodge!
