Old 3rd Jun 2020, 10:31 am   #21
G3PIJpeter
Default Re: Valve testers and E88CC / ECC88 valves
Originally Posted by factory View Post
Could that batch be mislabelled?
Early on in this saga, I suspected the same and inspected the inside of one of the CV2492s with a x10 hand lens. Each of the pins was connected to the appropriate electrode.
The batch of ten was removed from a 1970s MOD signal generator sub-unit. It might be that they had had a hard life, even though their getters and external condition appeared pristine. All the other examples of E88CC and ECC88 that I have test OK for both triode sections.
Either these CV2492s are a duff lot or they do not have the same electrical characteristics as E88CCs (the commercial equivalent is given as E88CC/01). It might be possible, as suggested before, that these CV2492s give parasitic oscilation on the A2 side. I suppose the real test would be to put one into a working piece of equipment usually fitted with an E88CC - such as a 1950s state-of-the-art 2-metre convertor.
Many thanks for people's continuing suggestions.
- Peter
G3PIJpeter is offline
Old 6th Jun 2020, 9:45 am   #22
John_BS
John_BS's Avatar
What would happen if you connectd the screen to the cathode? i.e. pin 9 to selector 2?
John_BS is offline
